Old 05-16-2011, 07:14 PM   #1
NZ-FE Vios
Only Timing Chains
Drives: 09YarisSedan, 94Truck22re
My qualms are the affect on the factory warranty (i've rebuilt motors and don't have an issue with the actual installation of four bolts for the part), if I install it, the part has its 12 month/12k warranty but if in the unlikely event that my installation fails and causes another part to fail then I blow my factory warranty. If Toyota installs the part (and once again in the unlikely event) and it fails, its on them. I'm at 18k miles and this is the first car I've owned with a warranty so i really don't want to jeopardize it.
NZ-FE Vios is offline   Reply With Quote
Old 05-17-2011, 12:58 PM   #2
Jason@SportsCar
The only downside to the dealer is a little extra money.
But you are buying piece of mind. In addition to the part being covered by Toyota warranty when you have it installed by them, you are less likely to get hassled over any other rear suspension/axle/brake related issue if you needed service - none of that "oh your rear drums went bad because YOU installed this rear bar".
TRD CAI or TRD Rear Sway Bar .Kevin. Performance Modifications 27 10-31-2010 01:55 AM
My car after TRD Springs and Sway Bar GrimlockGT Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 03-25-2010 10:30 PM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
TRD Rear Sway Bar detroiter Items for Sale by private party 15 08-05-2009 01:01 AM
TRD Springs Shocks and Sway Bars IN STOCK Sparks Toyota-TRD Sparks Toyota 0 03-12-2009 09:54 AM
