Old 10-25-2010, 11:09 PM   #1
.Kevin.
I ain't even mad
.Kevin.'s Avatar
TRD CAI or TRD Rear Sway Bar
Alright if a vehicle has none of the above which is better to go with.
What makes the TRD CAI above the stock one? other than appearance.
And whatm akes the sway bar so much more worth it? Is it because you can drive faster and feel smoother?
converse fellas.
Old 10-25-2010, 11:15 PM   #2
sickpuppy1
Drives: 2010 Yaris Sedan
The CAI gives it a llittle better breathing at top end. The sway bar makes it more stable on the highway, less darty and much more stable in cross winds. And pitching it into a corner is way fun! And by the way, the TRD swayar is 19mmm, just like the Ultimate Racing 19mm the sell at Microimage.com ( a sponser of the site) But the UR bar is substantially less $ . They also sell the 23mm which is more jun yet!!
Old 10-25-2010, 11:16 PM   #3
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Which would you pick? Is the CAI more cosmetic? And how the hell do you get one I dont see it available for accessories on my toyota websie just the sway bar
Old 10-26-2010, 06:00 AM   #4
Freedan
Drives: 2010 Yaris Bayou Blue 3DR Lift
I'd go with the 23mm UR sway bar. Only reason I'm suggesting the sway bar is that I have it installed on my Yaris and I just love it.
I won't be getting a CAI just yet. Going to wait for the Turbo Kit Garm is putting out soon.
Hope the turbo is within my budget.
Freedan is offline   Reply With Quote
Old 10-26-2010, 06:10 AM   #5
djct_watt
Drives: 2010 NCP91 5spd
The sway bar will be far more useable. The intake is not going to magically make your car faster than everything else on the road. . . it will still be slow, except you'll have MAYBE 1 more HP, which you honestly won't be able to notice, unless you imagine it in your head like most people. The main benefit of an intake, IMO, is the deeper intake growl, which definitely can be worth it. But between the two, get the sway bar.
djct_watt is offline   Reply With Quote
Old 10-26-2010, 12:06 PM   #6
Uber_Otter
Uber_Otter's Avatar
Drives: Black XA not yaris but close
Sway bar first, before anything. My TRD is 22mm. You won't get more power but you'll be driving faster all the time. The car will feel 3x more go-cart than it does now.
Uber_Otter is offline   Reply With Quote
Old 10-26-2010, 12:10 PM   #7
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Any reason why you are going TRD specifically?
Old 10-26-2010, 12:45 PM   #8
The TRD rear sway bar is 19mm.
Old 10-26-2010, 01:53 PM   #9
Originally Posted by .Kevin. View Post
converse fellas.
All the other threads on intakes and sway bars has conversed me out.
Old 10-26-2010, 01:58 PM   #10
^ true, the information is on here many times over. Kevin, do a search and read.
Old 10-26-2010, 02:14 PM   #11
kimona
kimona's Avatar
Drives: 2014 White VITZ
Save some money. Get the UR 19mm anti-sway bar from MI. It's all you'll ever need on the road.
Old 10-26-2010, 02:37 PM   #12
.Kevin.
I ain't even mad
.Kevin.'s Avatar
My car kind of has TRD printed on the side rear panels so yeah and I llike the TRD branch myself. So why not support it.
"Why like ___ soccer team when ___ is just as good if not better"
Old 10-26-2010, 02:43 PM   #13
because:
1. You can support a YarisWorld vendor instead
2. The UR sway bar is less expensive, and the same thing.
Old 10-26-2010, 02:47 PM   #14
.Kevin.
I ain't even mad
.Kevin.'s Avatar
because:
Tried supporting a YW vendor with like 8 purchases but got them all here in a day and installed the next lol.
Though I cant argue with #2
Old 10-27-2010, 10:31 AM   #15
detroiter
detroiter's Avatar
Be careful on buying a sway bar...chances are your going to end up having to buy tires sooner ;)
Not due to the part being there...bu due to the fact you won't stop being able to fly around corners :)
Old 10-27-2010, 11:35 AM   #16
.Kevin.
I ain't even mad
.Kevin.'s Avatar
What does that mean?
Old 10-27-2010, 11:38 AM   #17
djct_watt
It means you should get the sway bar.
Old 10-27-2010, 12:58 PM   #18
detroiter
detroiter's Avatar
It means that you will take corners faster because it's so fun and with the sway bar, your car will handle it easier going faster around the corners. Sooo the price you pay for faster speeds around corners is worn out edges on tires.
If you can contain yourself and drive normal speeds, you have nothing to worry about. But the ability is there if you feel the urge :)
TRD rear sway bar? Lewis DIY / Maintenance / Service 26 09-10-2013 02:10 PM
My Ultra Racing rear sway bar install CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 49 03-03-2011 02:08 AM
rear sway bar needed vten Willing to Buy by private party 11 11-22-2009 11:50 PM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 06:07 AM
TRD rear sway bar cali yaris Items for Sale by private party 19 05-23-2009 05:23 PM
