Old 05-16-2011, 11:20 PM   #1
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
let me know how that goes, I'd like to get mine working properly as well.. heh
Old 05-17-2011, 01:39 AM   #2
special_k_828
Drives: 2006 Yaris CE 2-Door Hatchback
Well finally got everything all installed. Would not say it was smooth at ALL. Ended up having to partially cut a piece of the bushing off. The tool that finally got the brass piece off was a pair of short blade clipper/pliers. I grabbed the two sides of the bushing and used the other piece of the linkage as leverage. That, and having been soaked in liquid wrench for a while, finally freed it.
I then discovered the NST SSK hole was not big enough to slip over the linkage piece with the cotter pin so I had to bore it out a bit with my drill. I put the rubber bushing back into place (so it's actually several pieces at the moment until I have time to go to the junkyard and find another one) and placed it over the SSK piece. Shifts nice. Not that much shorter of a throw though but noticeable.
Here is a pic from a Corolla linkage with the same piece stuck! That brass piece is glued to the rubber bushing. I ended up ripping some of it off so I could get to the brass piece.
special_k_828 is offline   Reply With Quote
FS: Short Shifter and Bushing dwnhillskater Items for Sale by private party 4 04-14-2010 02:26 AM
NST shifter cable bushing users: Lube up! schleppy Performance Modifications 11 07-05-2009 08:47 PM
NST shifter linkage bushings... DerFlosser Performance Modifications 4 05-21-2009 08:33 PM
NST Shifter Bushing Kit ruimond Performance Modifications 5 12-06-2008 12:48 AM
NEW NST SS Shifter Bushing (AE86) NonStopTuning NonStopTuning 3 10-01-2007 03:12 PM
