#1 | |
![]() Drives: 2010 Yaris Join Date: May 2011
![]() Are you suggesting there is an issue with Yaris timing chain tensioners ?? What year / engine ?? This thread is in regards to a UK model.... My post does not identify any issues with any parts, my comments reference how this can easily happen by lack of maintenance,, which I've seen a few times,, Quote:
Only Timing Chains
Drives: 09YarisSedan, 94Truck22re Join Date: May 2011
No No, I was referencing DMZ post - not really sure if it was in reference to the issue at hand and how it would apply to the original issue....as he quoted my message....
220mile - sweet you've gotta love that 22R engine, I have a few buddies that pound on them with 36" tires,, I personally do it with my 3B diesel...404km and counting... |
#4 | |
![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2011
It is the same with motorcycle chains. There is a common myth that they stretch with age. If you measure one new and after 50K miles, the length is the same. The sprockets get worn and oval out, hence the need to adjust or tighten it periodically. Sorry about the confusion. I am inclined to believe that a maintained Yaris should be able to go 400k without having a timing chain issue. |
Really,, ok maybe stretch is perhaps too lay - the pins and bushes elongate causing poor mesh with the sprocket - resulting in premature wearing of the sprocket teeth,, culprit chain.... overheat it by lack of lubrication or poor lubrication pins wear chain gets longer...
Don't have acceptable tolerance specs handy,,, |
#6 | |
Only Happy When it Rains
Colin Chapman disciple |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
Looks like the OP has left the forum and hasnt returned to update us on his cars condition.Did we waste our time responding?Did the Op get any help out of our responses? Was the timing chain defective? should i worry about the Timing chain in my car?
Thanks Rampage maybe next time you join a forum you may want to read up on Forum etiquette before leaving us all hanging.. |
| Tags |
| timing chain |
| australian vs american models: timing chain | hoobyjuice | DIY / Maintenance / Service | 3 | 06-16-2009 09:25 AM |
| wtf?! timing chain cover split?! | jeff69dini | DIY / Maintenance / Service | 9 | 08-01-2007 12:11 PM |
