Old 05-17-2011, 10:45 AM   #1
NZ-FE Vios
Only Timing Chains
Drives: 09YarisSedan, 94Truck22re
Originally Posted by brbo View Post
Are you suggesting there is an issue with Yaris timing chain tensioners ?? What year / engine ??
Sorry I was just responding as a reference. If the tensioner failed, the vehicle would not be able to be driven at least that was the case on the truck.
NZ-FE Vios is offline   Reply With Quote
Old 05-17-2011, 10:51 AM   #2
brbo
Drives: 2010 Yaris
No No, I was referencing DMZ post - not really sure if it was in reference to the issue at hand and how it would apply to the original issue....as he quoted my message....
220mile - sweet you've gotta love that 22R engine, I have a few buddies that pound on them with 36" tires,, I personally do it with my 3B diesel...404km and counting...
brbo is offline   Reply With Quote
Old 05-17-2011, 02:19 PM   #3
DMZ
DMZ's Avatar
Drives: 2007 Yaris LB
My post was an attempt to clarify the fact that timing chains do not stretch. The gears wear and that what results in slack.
It is the same with motorcycle chains. There is a common myth that they stretch with age. If you measure one new and after 50K miles, the length is the same. The sprockets get worn and oval out, hence the need to adjust or tighten it periodically.
Sorry about the confusion. I am inclined to believe that a maintained Yaris should be able to go 400k without having a timing chain issue.
DMZ is offline   Reply With Quote
Old 05-17-2011, 11:06 PM   #4
brbo
Drives: 2010 Yaris
Really,, ok maybe stretch is perhaps too lay - the pins and bushes elongate causing poor mesh with the sprocket - resulting in premature wearing of the sprocket teeth,, culprit chain.... overheat it by lack of lubrication or poor lubrication pins wear chain gets longer...
Don't have acceptable tolerance specs handy,,,
Old 05-18-2011, 12:22 AM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
they might not stretch like belts, but i bet if you don't change the oil enough and ignore other maintenance items you could get them to weaken and stretch some.
Colin Chapman disciple
timing chain
australian vs american models: timing chain hoobyjuice DIY / Maintenance / Service 3 06-16-2009 09:25 AM
wtf?! timing chain cover split?! jeff69dini DIY / Maintenance / Service 9 08-01-2007 12:11 PM
