![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
It looks like you can choose 5 or 10 flashes, then the light stays on solid. So yes, you would have to take your foot off the brake, and re-apply to get it to flash 5/10 times again. But if you turn on the 7 second thing, it would flash until after 7 seconds. Make sense?
![]() ![]() ![]() Drives: 2008 5-door Yaris Hatchback Join Date: Oct 2008
Installed mine tonight using the original DIY, inside the driver side upper trunk panel (where the rear seat belt runs into).
Easy to pop off the panels, just be careful you don't lose any of those white plastic snap pins, or else you'll be dismantling the lower part of the trunk panels to find them (guilty as charged!). Works perfectly, and DIY is 100% accurate information. I really like the look. The delay is best for me since I get stuck in city traffic a lot and don't want it blinking constantly. |
#3 | |
![]() ![]() Drives: toyota yaris Join Date: Jul 2010
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 06:05 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
