![]() ![]() ![]() Drives: 2008 5 sp. LB Join Date: Oct 2010
Higher and higher gearing can be overdone. Just try driving the 5 speed in top gear at 35 mph and see how good of mileage you get. While the rpm's may be construed as "high" (relative to what....) the engine is not working hard/manifold pressure is low. Granted it is a balancing act, and in theory I'd like a 10 speed to play around with, but I don't sweat not having a higher gear in my Yaris as much as I do not being able to open my rear windows!
I've seen different airplane drivers fooling around with ground adjustable pitch props, going coarser and coarser (like higher and higher gearing) hoping and getting lower revs at a certain cruise speed, but you reach a point where the economy doesn't improve past a certain point. Let's face it the Yaris is a inexpensive car, so the engineers' split the difference, a 5 speed instead of a 6 is one of those compromises. If you are obsessed with lower revs at a certain speed, it would be more practical to get larger tires and wheels. Keep in mind they'd weigh more and raise the vehicle thus more drag, probably canceling out any gains in MPG. |
#2 | |
![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2011
#3 | |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
Echo was 3.54 final ratio. Yaris appears to be 3.72 That is only 5% different...sure seems more. The diesel in Eruope has a six speed with 3.55 final ratio and more overdrive on the higher gears. It would be nice to get ahold of one of those it it would bolt to a gas engine. |
#4 | |
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
| Yaris vs MR2 Spyder | regal | Off-topic / Other Cars / Everything else Discussions | 36 | 01-25-2026 12:56 PM |
| Yaris TS 1.8L History and Specs | CASTREX | Yaris TS Talk | 52 | 10-27-2009 05:06 PM |
| What the Yaris community needs to take the Yaris to the next level | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 124 | 04-30-2009 02:03 PM |
