Old 05-24-2011, 12:05 PM   #22
Idahotom
Drives: 2008 5 sp. LB
Higher and higher gearing can be overdone. Just try driving the 5 speed in top gear at 35 mph and see how good of mileage you get. While the rpm's may be construed as "high" (relative to what....) the engine is not working hard/manifold pressure is low. Granted it is a balancing act, and in theory I'd like a 10 speed to play around with, but I don't sweat not having a higher gear in my Yaris as much as I do not being able to open my rear windows!
I've seen different airplane drivers fooling around with ground adjustable pitch props, going coarser and coarser (like higher and higher gearing) hoping and getting lower revs at a certain cruise speed, but you reach a point where the economy doesn't improve past a certain point. Let's face it the Yaris is a inexpensive car, so the engineers' split the difference, a 5 speed instead of a 6 is one of those compromises. If you are obsessed with lower revs at a certain speed, it would be more practical to get larger tires and wheels. Keep in mind they'd weigh more and raise the vehicle thus more drag, probably canceling out any gains in MPG.
Idahotom is offline   Reply With Quote
Yaris vs MR2 Spyder regal Off-topic / Other Cars / Everything else Discussions 36 01-25-2026 12:56 PM
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 05:06 PM
What the Yaris community needs to take the Yaris to the next level regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 124 04-30-2009 02:03 PM
