![]() ![]() Drives: 2009 toyota yaris 1.3 sedan Join Date: Apr 2010
HI
i'm calling for help from EGYPT ! our toyota dealer here sucks and uses low-quality Mobil 1 fully synthetic motor oil 5w-40 ... Engine sound is too high! (10000 km so far) ![]() I DON'T WANT TO USE THAT!! right now , i'm using toyota genuine motor oil (20w-50) mineral oil .. (much smoother engine now) ![]() (catalog says 20w-50 or 15w-40 multigrade SL) HELP ME OUT GUYS ... i'm doing okay or should i switch to synthetic ? note : Driving in EGYPT is pretty bad! Heavy traffic + short distances + HOT Temp. (40C In summer & 8C in winter) .... THNX! |
![]() ![]() Drives: 2008 Red Yaris LB Join Date: Nov 2008
I would say the fully synthetic Mobile 1 is the superior oil
![]() ![]() ![]() Drives: '09 Yaris & '10 Auris Join Date: Apr 2009
My (genuine toyota) oil didn't change color after 6.000 km, too. I see no problem there. Mobil 1 FS oils are well known and high quality oils.
#5 | |
i guess many ppl can confirm that right? plus , in EGYPT , its really dusty weather and low quality fuel , (can you imagine changing the air filter every15,000 km?!) so , my oil should be good enough in cleaning engine interior and handling heavy traffic! |
I don`t think the Toyota Genuine Oil is bad. 6000 km ain't much and we don't have any heavy conditions here. Car only got 13.000 km so there should not be much residue inside the engine.
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
Oil color is not a really reliable method of determining how good of a job an oil is doing. Most folks I know with a Yaris report their oil stays very clean looking for long periods no matter what oil they use.
An oil turning dark quickly may simply be oxidizing and actually building engine deposits, to give an example. Bottom line: choose any quality oil you like from 0W-20 to 20W-50, change at a reasonable interval, make sure your air filtration is working good and your Yaris will go further than most of us would ever care to drive them! |
![]() ![]() Drives: 2007 Yaris HB Join Date: Dec 2009
Either oil should work. I wouldn't worry too much. Here in the US they spec 5w30 and 5w20 for the Yaris, so I wouldn't worry that a 40 weight oil might be too thin.
so , it wont matter if its synthetic or mineral ?
Only Happy When it Rains
no. What does Toyota tell you to use in your car? For the US it is on the oil cap.
Colin Chapman disciple |
There's not a lot of difference in your scenario. In a warm weather climate with a car that doesn't have a high performance or turbo-charged engine, the benefits of a synthetic are minor. If you want to use a synthetic for a little more peace of mind, go ahead, but it probably won't affect the longevity of your engine to any great degree. As long as you use a quality oil and change it regularly, I wouldn't worry. |
#13 | |
#14 | |
But especially keep watch on your cooling system. Check your coolant level regularly and watch for leaks! More engines end up on the scrap heap from coolant problems than from oil problems. |
#15 | |
considering synthetic oils ... what do you recommend? |
#16 |
Crazy Oil Sniffer
Very well said, Happy Little Pony!
#17 |
![]() ![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Aug 2010
I run Pennzoil Platinum 5w-30 that I get for $22 at Walmart and I take my car to lapping days, and I still change it every 2 lapping days or 9000kms, whichever comes first.
My oil has around 8000kms, has been through this past winter and a lapping day, and is dark brown.
2006 Saturn Ion Redline 2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold 2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped |
#18 |
mobil 1 , castrol , shell , total ... All are API SL
We got some good stuff ... I think i'll buy my oil next time from saudi arabia (the country in the movie kingdom :-D) since they are leading in oil industries ... |
| Engine oil pump? | zahirrahman | DIY / Maintenance / Service | 3 | 09-30-2010 01:06 PM |
| Performance engine Oil | xbalance | Performance Modifications | 2 | 07-14-2009 03:32 AM |
| Synth Blend Oils | scape | DIY / Maintenance / Service | 7 | 07-12-2009 01:55 PM |
| Spilled oil on engine | eii | DIY / Maintenance / Service | 11 | 01-28-2009 11:30 AM |
| Compiled 1NZFE Used Oil Analysis | craigq | DIY / Maintenance / Service | 7 | 09-10-2007 04:27 PM |
