Old 02-27-2007, 03:46 PM   #1
Razr
YRS WHOR
Razr's Avatar
Drives: White 2007 Yaris E-Limited 5dr
Originally Posted by magoo_lc1 View Post
Honest to goodness if this for front passengers only which it should be , mount the tweeters in the kickpanel. I have not looked at yaris kick panel but they shoud fit. Buy a componet set with aimable cups are just make a spacer to aim them up at you. PVC painted black works well. If you listen to live music its always in front of you right? Go for a kick panel or door panel install.. I would be nice if you could mount the tweet and mid bass in the door for equal sount length.
The front A pillars have a flat section just right for mounting tweeters, and it's coincidentally the same distance from your ears as the midbass in the doors - the only problem is that there's so much separation between the drivers that you'd need a 500Hz crossover on the tweeter to make it work nicely (err, don't try this! ).
From a non-purist angle though, the A pillars would be a very straight-forward install, and the symmetrical dash will definately lend itself to creating a more balanced soundstage -- you won't have the typical near-field, sound stage destroying reflections happening on the driver's side of most cars due to their off-center instrument panel bump.
As much as I normally agree with kick panel mounts, this is a small car with a more upright seating position than normal. Legs, dash and console are definately going to get in the way of kickpanel mounted tweeters.
I suppose the bottom line is that the Yaris is never going to be an uber SQ car.
Razr is offline   Reply With Quote
Old 02-28-2007, 12:58 AM   #2
Actually, that's exactly where mine are in the front
I'm not 100% sure how they are mounted as the guys at the workshop took care of it. It's certainly not perfect, but it's a clean look and sounds just fine.
DIY 07 Sedan Rear Speaker install vodkalush DIY / Maintenance / Service 32 10-20-2017 03:40 PM
Can I install these speakers to the front and rear of my liftback? W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 33 02-25-2009 02:23 PM
60/40 rear seat in LB - anyone install one? wilco Cosmetic Modifications (Exterior/Interior) 0 08-20-2006 06:42 PM
