It is more likely a jammed mechanical linkage than a short. If you pull the hatch trim, you can get at the wiper assembly. There are two screws that mount the motor to the gearbox. If you pull the motor off of the gear box and run the wiper, the motor should spin and if it doesn't blow the fuse then something is jammed in the gearbox. Four more screws hold the cover on the gearbox - remove those and see if it is something fixable.
| Ultra Racing 23mm Rear Stabilizer Bar | Loren | Performance Modifications | 62 | 05-18-2009 07:20 PM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
| Does your Rear wiper sqeak like crazy? is this normal? | Syroyizhka | DIY / Maintenance / Service | 18 | 04-16-2009 08:11 PM |
