Old 06-08-2011, 08:28 AM   #1
Originally Posted by bizarro View Post
Ok, sounds promising - and where would those wires be accessed - in the fusebox on the LHS (i.e. to the left of the steering wheel in the US, behind the parcel shelf in the UK)?
Right at the connector for the turn signal stalk, so you remove the lower steering wheel cover to gain access.
Old 06-08-2011, 08:30 AM   #2
bizarro
Drives: Yaris
Okay, I see. And which colour wire would I tap for the 12V supply?
bizarro is offline   Reply With Quote
Old 06-08-2011, 08:40 AM   #3
The pink wire on the keyswitch would be the easiest (provided you have a keyswitch and not the smart entry system).
Old 06-08-2011, 08:49 AM   #4
bizarro
Drives: Yaris
Great. Thanks for all the help. I'll post how I get on.
Old 06-12-2011, 09:07 AM   #5
bizarro
Drives: Yaris
Ahem - the idea got vetoed by my wife. She didn't like the idea of the buzzer going off continually while the indicator was on. Fair point.
So - I've been trying to locate the actual clicker thing. Seems to be under the aforementioned lower steering wheel cover. How is that removed? Does the steering wheel have to be removed?
Old 06-12-2011, 10:44 PM   #6
It's actually on the face of the under dash fuse panel. It is the largest relay on there and says FLASHER on it.
Removing Rear Seat bronsin DIY / Maintenance / Service 4 04-11-2011 02:34 PM
Door trigger for Rear Right RR door missing enve1160 In Car Entertainment + Electronics (audio / video / alarm) 12 12-29-2010 10:14 PM
