Old 06-08-2011, 08:26 AM   #7
bizarro
Drives: Yaris
You could wire the chimes to the turn signal stalk instead of to the bulbs, that way they will receive a constant instead of pulsed feed. The black wire on the stalk connector is the left and the violet is the right. You would connect those wires to the negative lead of the buzzer and would connect the positive lead of the buzzers to a +12V source.
Ok, sounds promising - and where would those wires be accessed - in the fusebox on the LHS (i.e. to the left of the steering wheel in the US, behind the parcel shelf in the UK)?
bizarro is offline   Reply With Quote
Removing Rear Seat bronsin DIY / Maintenance / Service 4 04-11-2011 02:34 PM
Door trigger for Rear Right RR door missing enve1160 In Car Entertainment + Electronics (audio / video / alarm) 12 12-29-2010 10:14 PM
