Old 06-14-2011, 02:36 AM   #1
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Lightbulb
Originally Posted by mazilla View Post
I don't know what else there is besides Dynamat to compare it to(I've never dealt with anything else).
I know what I'm going to suggest it's not cheap but here we go any way...
-On metal CLD Tiles to cover 25% of the flat areas "This would take care of the resonances - is just a slightly catchy name for 6” X 10” pieces of constrained layer damper – what we’ve traditionally called sound deadener. If you’ve been doing any research, you have probably come across the usual arguments: “Buy the good stuff and cover everything” or “Buy the cheap stuff and cover everything with multiple layers.
The usual arguments miss the point. Products like this are vibration dampers. Their only purpose is to control resonance in a vehicle’s panels. Controlling resonance is the absolutely critical first step in any sound deadening project, but more isn’t better and trying to use a CLD to block sound is too expensive, too labor intensive and makes it unnecessarily difficult to do future vehicle maintenance. The old adage about using the right tool for the job has never been truer.
-One layer of 1/4" CCF (Closed Cell Faom) is the ideal decoupler for barriers and trim panels in a motor vehicle. It will also absorb some very high frequency noise, but let’s not get carried away with that aspect of its use.
When you want to block noise, you need a massive barrier like Mass Loaded Vinyl Barrier. For a barrier to work well, it should be floated above the substrate to which it is attached. If the substrate has any residual resonance after treating it with CLD Tiles, using CCF as a cushion will stop the resonance from exciting the barrier material. It also creates a more complex path for the sound to travel through, further increasing the effectiveness of the barrier.
When trim panels buzz or rattle, lining them with CCF will isolate them from whatever they are rattling against. Problem solved.
-MLV (mass loaded vinyl)
Once you've applied CLD Tiles, turn your attention to blocking noise. Controlling panel resonance is an essential step to prevent transmission of noise, but you need to block noise at the point of entry to achieve the kind of quiet ride we all want.
Many of us have tried following the old way of sound deadening a car - piling on layer after layer of vibration damper. The doors close with a satisfying "thunk" and the car sounds completely dead when you tap on its panels, but most of us have been disappointed to take our masterpiece out for a ride, only to discover that traffic, road, engine and exhaust noise are only slightly diminished. This is yet another case of needing to use the right tool for the job. Using a separate barrier to block sound is the right way to deal with the problem. The result will be much better, cost less and take a lot less work.
There is a lot more, but this is a good start... Source http://www.sounddeadenershowdown.com
D.
CLA 250, 4MATIC
Old 06-14-2011, 03:30 AM   #2
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
D.
NAILED IT!
Good read, thank you.
I'm happy where I'm at right now. My other daily driver is a lifted Wrangler so this Yaris is very quiet comparatively. Besides, the road noise gets quieter as the stereo volume gets louder.
-Type 07 FFL-
My odometer 03/11
Old 06-18-2011, 10:00 AM   #3
Viperoni
Drives: 2005 Toyota Echo
D.
Best post.
Also, roofing products and the like from Home Depot/Lowes are NOT good CLD's (or sound deadeners) because of their construction.
They also don't do much, so don't spend much money on it either.
I found a very noticeable difference when I made a "sheet" of MLV (Mass loaded vinyl) that I put between my rear inner door skins and door panels.
2006 Saturn Ion Redline
Old 06-18-2011, 10:18 AM   #4
derickveliz2
Originally Posted by Viperoni View Post
Best post.
Thanks,
here is a long story, learning process and time consuming adventure...
LINK
D.
CLA 250, 4MATIC
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-04-2011 11:56 PM
Yaris SR - JL Audio Install + Sound Deadening (Progress Thread) Nips In Car Entertainment + Electronics (audio / video / alarm) 8 03-18-2011 12:42 AM
cheap sound deadening p123456789 In Car Entertainment + Electronics (audio / video / alarm) 21 11-03-2010 05:06 PM
sound deadening material??? are names worth it? severous01 In Car Entertainment + Electronics (audio / video / alarm) 15 08-07-2010 09:06 PM
Sound deadening questions cast DIY / Maintenance / Service 7 03-16-2010 12:46 PM
