Old 11-03-2010, 12:04 AM   #1
p123456789
Drives: 07 lb jeep tj
cheap sound deadening
had anyone here ever used peel n seal or any other lowes type sound deadening as a cheap alternative. I was replacing the rear speakers in my lb to find NO sound deadening at all all you can see it the sheet metal.
p123456789 is offline   Reply With Quote
Old 11-03-2010, 03:09 AM   #2
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Raamat.com is a good quality site to get deadening.
― Thomas Paine
Old 11-03-2010, 04:15 AM   #3
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Thumbs up
http://www.raamaudio.com/
it's a good starting point.
This is another option, but all depends on what you want!
http://www.soundproofing.org/
Derick
CLA 250, 4MATIC
Old 11-03-2010, 11:17 AM   #4
sqcomp
Roadrunner Jr.
sqcomp's Avatar
That first option derick gave is the one.
― Thomas Paine
Old 11-03-2010, 12:35 PM   #5
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
what would you put ? peal and seal every where in the car ?
Interior:ALL red, black roof
Old 11-03-2010, 03:14 PM   #6
Astroman
Modded Moderator
Astroman's Avatar
There ya go.
Old 11-03-2010, 03:29 PM   #7
derickveliz2
If I where you,
I would start putting a complete layer of MAT from raamaudio.com in the TRUNK
Then will treat the same way the front doors
This would help more acoustics of your woofers/speakers than blocking road noise, but it's a good start
D.
CLA 250, 4MATIC
Old 11-03-2010, 03:45 PM   #8
packetrace
packetrace's Avatar
What quantity will I need to treat the front door and the trunk ?
HOW MANY
And for the floor it's MAT + MLV ?
Old 11-03-2010, 04:12 PM   #9
derickveliz2
You asked for cheap, get a roll of this:
LINK 62.5 sqfeet
Old 11-03-2010, 04:19 PM   #10
packetrace
packetrace's Avatar
Old 11-03-2010, 04:41 PM   #11
derickveliz2
"And for the floor it's MAT + MLV ?"
MLV it's a sound barrier and it's not cheap. (works great on the floors, wheel wells, Pillars and doors).
Works in junction with CLD Tiles (or a full layer of MAT) + CCFoam.
You can add a layer of CCFoam on top of the Mat then a layer of MLV on top of the CCFoam this system would help reduce road noise!
D.
Old 11-03-2010, 04:55 PM   #12
packetrace
packetrace's Avatar
And just to have a good sound quality....only use MAT would be great ?
Old 11-03-2010, 05:06 PM   #13
derickveliz2
Sound quality comes from your equipment
Road noise doesn't let you hear your music at low levels
Mat helps to prevent vibrations, produced by woofers, and road noise.
Old 11-03-2010, 05:09 PM   #14
packetrace
packetrace's Avatar
So with my big woofer that I want to be loud....i use mat ? is that right ?
in the trunk and the froont door ?
so it will prevent vibrations that we dont want....the woofer vibrate parts of the car so it make the sound being bad ?
Old 11-03-2010, 05:21 PM   #15
derickveliz2
Have you ever heard a car with a loud system and the trunk + license plate vibrate like crazy! that is why you use MAT. But if you use only MAT to prevent vibrations and block the road noise you would need at least 3 or 4 layers of MAT. That is when using MLV comes appropriate.
Old 11-03-2010, 05:29 PM   #16
packetrace
packetrace's Avatar
Thats what I mean with vibrations we don't want like the license plat...:)
So I'll put One layer of MAT in the trunk and in the front door :)
on roll is enough ?
Old 11-03-2010, 05:40 PM   #17
derickveliz2
one roll is enough ?
It's a good starting point depending on how crazy you want to go.
I didn't use a lot of MAT, most of my deadening was CLD Tiles + CCF + MLV and then I used about 45 sqfeet of MAT, to feel the gaps (wheel wells & trunk) and front doors.
Old 11-03-2010, 05:54 PM   #18
packetrace
packetrace's Avatar
I for sure dont want to go crazy as you went....remember I'm only a student !
I'll go with with it !
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-05-2011 12:56 AM
