Old 06-14-2011, 07:08 PM   #1
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
50 series will help.....the rears will be close to flush to the side or close to poke out.......just a small amount camber will take care of it,rub,yes on bumps,uneven surfaces,etc....
the fronts will stick out fairly flush.....rubbing....dear god yes....more camber....
can you drive safely with it....yes...roll fenders,add camber,and enjoy the wonderful way it looks,save some money for new tires as camber wear will kill them off...
two roads of thought.....stay safe and drive it and enjoy it.....or put it on and run it and maintain it....sidewalls are fairly tough and rolling fenders is great to keep them safe.....it makes a nasty sound when it rubs but you get used to it and after a while you dont notice it much....ok I lied there.....the sound it makes will haunt you...lol
Old 06-14-2011, 11:11 PM   #2
jerome
Toyota
Drives: '11 5dr/5spd yaris
so definitely go with a camber kit for the front and rear? recommendations on what to get?
what if i go +35? would i still need to do any of this? could i run 195/55/15 on +35?
i know about the nasty sound... i had an '06 xa prior to this on 16x7 volks w/+33 offset in the front and +23 offset in the back... trust me... lol
jerome is offline   Reply With Quote
Old 06-15-2011, 12:27 PM   #3
33OH
Drives: '08 Yaris
195/55/15 +35 will be fine. Pretty flush in the front, a little sunken in the back. But shouldn't rub.
16x7 - 40mm offset - 195/50/16 rubbing like a fat kid at a Rave 3cyltrbo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 04-14-2011 03:42 PM
Installed 10mm PG spacers on a 15x7 +25 wheel kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-27-2009 07:10 PM
hard to find anything that's NOT 38 or 40 offset... will these fit without rubbing? tonyg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 03-19-2009 08:53 PM
Ideal Offset? 15x7 ET42 Wheels TRD_Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-18-2006 04:12 AM
