Old 06-15-2011, 10:17 PM   #1
TRD.RiC
Drives: 09 Yaris RS
i had +30 offset on 195/55r15 and i am on coilover with 2.4 camber at the front, none at the back. big bumps on the road it will rub at the back on the sidewall of the tire and at the front ull kill your inner fender. doesnt matter cuz its hella flush :)
TRD.RiC is offline   Reply With Quote
Old 06-16-2011, 12:42 AM   #2
jerome
Toyota
Drives: '11 5dr/5spd yaris
Originally Posted by 33OH View Post
195/55/15 +35 will be fine. Pretty flush in the front, a little sunken in the back. But shouldn't rub.
to avoid that 'sunken' look could i add camber bolts in the rear + hub spacer to eliminate rubbing?
Originally Posted by marlondog View Post
One thing you can do is take the wheels to a machine shop, and have a few mm shaved off to bring the wheels a little in. You will def need some camber bolts, and you should be ok with -1 of wheel tuck. What wheels are you looking at getting?
never knew you could even do that with wheels but thanks for the suggestion. well, i'm looking at both ends of the price spectrum... RBs... but also RE30s...
why none in the back? i shredded a set of tires after running +33/+23 in my xa... learned my lesson there and had to do fender work... don't really wanna go that route again... lol
jerome is offline   Reply With Quote
Old 06-16-2011, 07:55 AM   #3
33OH
Drives: '08 Yaris
Yes, I'm actually running a 15x6.5 +21 offset (+38 offset wheels with 17mm of spacers) in the rear right now, no camber (but rolled fenders) with no rubbing. Tire size 185/60/15.
I also ran some 15x7's with 195/50/15's, +19 offset rear, no rubbing. I'm on DF210's btw.
16x7 - 40mm offset - 195/50/16 rubbing like a fat kid at a Rave 3cyltrbo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 04-14-2011 03:42 PM
Installed 10mm PG spacers on a 15x7 +25 wheel kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-27-2009 07:10 PM
hard to find anything that's NOT 38 or 40 offset... will these fit without rubbing? tonyg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 03-19-2009 08:53 PM
Ideal Offset? 15x7 ET42 Wheels TRD_Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-18-2006 04:12 AM
