Old 06-19-2011, 04:25 PM   #1
Yaris PAVEL94
The ignition is not the fuse I'm driving it right now but I by passed the ignition and if I turn it off I can't start it
Yaris PAVEL94 is offline   Reply With Quote
Old 06-19-2011, 04:43 PM   #2
Did you bypass by jumping 12 Volts to the ignition switch connector?
If that's the case, then the issue is most likely the IG2 relay, which is part of the "Integration Relay", which the is chunk where the AM2 fuse plugs into.
yaris won't start, engine truns over but won't start. zara616 General Yaris / Vitz Discussion 16 09-05-2021 11:39 AM
Yaris starts then it wont start. wush11 General Yaris / Vitz Discussion 18 01-05-2011 11:53 AM
Let's start a Yaris Club, each member has a specific number decal Yawesh General Yaris / Vitz Discussion 48 04-10-2009 10:49 PM
