![]() ![]() Drives: 2007 Yaris S Join Date: Aug 2010
Yaris wont start
Okay My yaris wont start because of the ignition wire doesnt put any power in the starter and I dont know where the ignition wire goes to? please help
The gray ignition wire is fed 12 Volts by the 15A AM2 fuse, located in the under hood fuse panel.
And now my radio and dome light doesn't work
For that, the DOME fuse.
![]() Drives: 2009 Yaris sedan Join Date: Jun 2011
There are 3 spare fuses in the fuse box that you can use . I blew the dome light fuse and mistakenly took out the ignition fuse thinking its the spare.
Ignition fuse is on the upper panel of the fuse box. There should be 3 fuses there, ignition being the middle one thats blue . I completely freaked when I changed the OEM radio and then my car wouldn't start
Its not the fuse
Which is not the fuse the ignition or radio issue?
So car dosnt start radio wont turn on and interior lights dont work..... stupid question but did you check the battery. Perhaps you left a map light or something on overnight.
The ignition is not the fuse I'm driving it right now but I by passed the ignition and if I turn it off I can't start it
#10 | |
If that's the case, then the issue is most likely the IG2 relay, which is part of the "Integration Relay", which the is chunk where the AM2 fuse plugs into.
yes and I can't see the ig2
I found it and I took it out! Should I change it? Is there a way to test it?
And the Id/up/Mir fuse under the dash does not light up witth the test light
#14 | |
The integration relay is expensive (dealer list is $121), so you want to be sure that it is really bad.
Yes there is a noice, and the dome light and radio fuses are good but they dont work. haha thisd is f***ed up
#16 | |
Also, the only thing between the DOME fuse and the battery is the 60A MAIN fusible link that is attached to the plastic block on the + battery terminal. It would be worth taking a peek at it.
The Am1 fuse is good I changed the tail light fuse, that was bad.
So, at this point, what works and what doesn't?
| yaris won't start, engine truns over but won't start. | zara616 | General Yaris / Vitz Discussion | 16 | 09-05-2021 11:39 AM |
| Yaris starts then it wont start. | wush11 | General Yaris / Vitz Discussion | 18 | 01-05-2011 11:53 AM |
| Let's start a Yaris Club, each member has a specific number decal | Yawesh | General Yaris / Vitz Discussion | 48 | 04-10-2009 10:49 PM |
