#19 |
![]() ![]() Drives: 2007 Yaris S Join Date: Aug 2010
Okay I got everything to work but that 12 volt purple wire I jumped it from the fuse box and it worked? Where does it go on the inside of the car?
#20 |
The violet one is the feed from the ST relay to the starter. It gets switched indirectly by the black wires on the ignition switch. If the ST relay is not getting energized, it could be the park/neutral switch if you have an auto or the clutch switch if you have an MT.
#21 |
Idk I'm just gonna take it to the dealer tommorow?
#22 |
It was a pink wire in the ignition, by the key
#23 |
That would be the ignition output wire on the ignition switch. Was the wire damaged?
| yaris won't start, engine truns over but won't start. | zara616 | General Yaris / Vitz Discussion | 16 | 09-05-2021 11:39 AM |
| Yaris starts then it wont start. | wush11 | General Yaris / Vitz Discussion | 18 | 01-05-2011 11:53 AM |
| Let's start a Yaris Club, each member has a specific number decal | Yawesh | General Yaris / Vitz Discussion | 48 | 04-10-2009 10:49 PM |
