Old 06-19-2011, 12:31 PM   #1
Yaris PAVEL94
Yaris wont start
Okay My yaris wont start because of the ignition wire doesnt put any power in the starter and I dont know where the ignition wire goes to? please help
Yaris PAVEL94 is offline   Reply With Quote
Old 06-19-2011, 01:16 PM   #2
The gray ignition wire is fed 12 Volts by the 15A AM2 fuse, located in the under hood fuse panel.
Old 06-19-2011, 01:53 PM   #3
Yaris PAVEL94
And now my radio and dome light doesn't work
Old 06-19-2011, 03:12 PM   #4
For that, the DOME fuse.
Old 06-19-2011, 03:29 PM   #5
Bar_Red_Yaris
Drives: 2009 Yaris sedan
There are 3 spare fuses in the fuse box that you can use . I blew the dome light fuse and mistakenly took out the ignition fuse thinking its the spare.
Ignition fuse is on the upper panel of the fuse box. There should be 3 fuses there, ignition being the middle one thats blue .
I completely freaked when I changed the OEM radio and then my car wouldn't start
Bar_Red_Yaris is offline   Reply With Quote
Old 06-19-2011, 03:45 PM   #6
Yaris PAVEL94
Its not the fuse
Old 06-19-2011, 04:15 PM   #7
Its not the fuse
Which is not the fuse the ignition or radio issue?
Old 06-19-2011, 04:18 PM   #8
YarisSedan
Drives: 08 Yaris Sedan
So car dosnt start radio wont turn on and interior lights dont work..... stupid question but did you check the battery. Perhaps you left a map light or something on overnight.
Old 06-19-2011, 04:25 PM   #9
Yaris PAVEL94
The ignition is not the fuse I'm driving it right now but I by passed the ignition and if I turn it off I can't start it
Old 06-19-2011, 04:43 PM   #10
Did you bypass by jumping 12 Volts to the ignition switch connector?
If that's the case, then the issue is most likely the IG2 relay, which is part of the "Integration Relay", which the is chunk where the AM2 fuse plugs into.
Old 06-19-2011, 05:30 PM   #11
Yaris PAVEL94
yes and I can't see the ig2
Old 06-19-2011, 05:36 PM   #12
Yaris PAVEL94
I found it and I took it out! Should I change it? Is there a way to test it?
Old 06-19-2011, 05:38 PM   #13
Yaris PAVEL94
And the Id/up/Mir fuse under the dash does not light up witth the test light
Old 06-19-2011, 07:17 PM   #14
I have a spare that I grabbed from a junkyard car. If you look at the picture below, I have a wire on pin 2 (pink) and on pin 3 (white). If I apply 12 volts across those two pins (2+, 3-), I hear the relay clink loudly. At the same time, if I measure continuity between 1 and 4 (the larger pins on either side of 2 and 3), I see continuity when I apply power to 2 and3.
The integration relay is expensive (dealer list is $121), so you want to be sure that it is really bad.
Name:  Integration Relay - IG2 Coil.jpg
Old 06-20-2011, 12:21 AM   #15
Yaris PAVEL94
Yes there is a noice, and the dome light and radio fuses are good but they dont work. haha thisd is f***ed up
Old 06-20-2011, 06:43 AM   #16
Check the AM1 fuse as well, which is a 25A fuse in the under dash fuse panel.
Also, the only thing between the DOME fuse and the battery is the 60A MAIN fusible link that is attached to the plastic block on the + battery terminal. It would be worth taking a peek at it.
Old 06-20-2011, 11:43 AM   #17
Yaris PAVEL94
The Am1 fuse is good I changed the tail light fuse, that was bad.
Old 06-20-2011, 11:45 AM   #18
So, at this point, what works and what doesn't?
yaris won't start, engine truns over but won't start. zara616 General Yaris / Vitz Discussion 16 09-05-2021 11:39 AM
Yaris starts then it wont start. wush11 General Yaris / Vitz Discussion 18 01-05-2011 11:53 AM
Let's start a Yaris Club, each member has a specific number decal Yawesh General Yaris / Vitz Discussion 48 04-10-2009 10:49 PM
