You shouldn't use the 10% underdrive NST pulley with a S/C, thats for a turbo or N/A setup. You're better off with the NST crank lite pulley.
If you really want to unleash the most power out of the kit, you should try and get ahold of a AEM FiC engine managment system and have a tuner retune your car with that. Instead of using the provided piggyback unit that comes with the blitz kit. My tuner was able to get me 20+ more WHP in my mid range with the greddy emanage ultimate (a different engine management), but he said he would have preferred the AEM FiC and would have probably gotten similar gains if not better from it. The blitz kit isn't at it's full potential with the supplied piggy back. |
#2 | |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
#3 | |
Also, depends what dyno you go on to see what numbers it will show, but it will be around 140whp. I dyno'd on two different dynos and i'm confident that it is near that number when retuning with a different management. |
#4 | |
I figured the Blitz (without management) to add another ~30 HP (unless I'm mistaken?), which would/should bring me up somewhere around 140-ish. If so, I can't really see the benefit of spending another $800 or so on the AEM and Boomslang. Do you recommend adding 1ZZ injectors with the Blitz? |
#5 | |
Your exhaust setup still isn't as free flowing as 2.25" headerback, but it IS better than stock. Are you implying you dyno'd 110whp with your current setup? Also, don't trust that supposed "30 whp" gain from the blitz kit." It's probably more like "20 whp." Again, i don't know what dyno you went on; all are calibrated differently. But I don't think you will hit 140whp with your setup if you just use the blitz piggyback. Maybe you will though on the dyno you have been going on. However, if i went on your same dyno with my setup, it'd probably show "160whp." If 140whp is the magic # you want to reach, then that's fine. But don't think that if you hit 140 on the dyno you go on, that it is the same as the 140 i hit after retuning with different management. Trust me, retuning with a different management unleashes a lot more power/potential from the compressor. Up to you if you want to do that or not. I'd suggest just wire up the piggyback yourself and drive it around like that for awhile. If you are content with the power, great! If not, you have another option with your setup to get more ponies. And that is always a great thing. |
+1 on that. I am happier than a pig in poop with mine as-is.
| blitz s/c | tropicalrs | Forced Induction Forum | 7 | 10-03-2011 09:32 AM |
| Blitz S/C a rebuilt and rebaged Toyota S/C? | Yaris0609 | Forced Induction Forum | 3 | 03-13-2010 12:21 AM |
| old article about blitz s/c but interesting info.. | AdeJong 03 | Forced Induction Forum | 4 | 09-18-2009 02:08 PM |
| fixed my blitz s/c problem for now | laszlo | Forced Induction Forum | 3 | 04-19-2009 10:24 PM |
| Blitz S/C on 08 Yaris | whooppee777 | Forced Induction Forum | 12 | 11-26-2008 01:45 PM |
