Old 07-08-2011, 11:36 AM   #6
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Originally Posted by MGargano View Post
I have an AFE intake, Megan header, 2.25" mid-pipe, and Megan axle-back.
I figured the Blitz (without management) to add another ~30 HP (unless I'm mistaken?), which would/should bring me up somewhere around 140-ish. If so, I can't really see the benefit of spending another $800 or so on the AEM and Boomslang.
Do you recommend adding 1ZZ injectors with the Blitz?
You don't NEED a wideband for the AFR. You could have them measure it if you dyno your car.
Your exhaust setup still isn't as free flowing as 2.25" headerback, but it IS better than stock. Are you implying you dyno'd 110whp with your current setup? Also, don't trust that supposed "30 whp" gain from the blitz kit." It's probably more like "20 whp."
Again, i don't know what dyno you went on; all are calibrated differently. But I don't think you will hit 140whp with your setup if you just use the blitz piggyback. Maybe you will though on the dyno you have been going on. However, if i went on your same dyno with my setup, it'd probably show "160whp."
If 140whp is the magic # you want to reach, then that's fine. But don't think that if you hit 140 on the dyno you go on, that it is the same as the 140 i hit after retuning with different management.
Trust me, retuning with a different management unleashes a lot more power/potential from the compressor. Up to you if you want to do that or not.
I'd suggest just wire up the piggyback yourself and drive it around like that for awhile. If you are content with the power, great! If not, you have another option with your setup to get more ponies. And that is always a great thing.
blitz s/c tropicalrs Forced Induction Forum 7 10-03-2011 09:32 AM
Blitz S/C a rebuilt and rebaged Toyota S/C? Yaris0609 Forced Induction Forum 3 03-13-2010 12:21 AM
old article about blitz s/c but interesting info.. AdeJong 03 Forced Induction Forum 4 09-18-2009 02:08 PM
fixed my blitz s/c problem for now laszlo Forced Induction Forum 3 04-19-2009 10:24 PM
Blitz S/C on 08 Yaris whooppee777 Forced Induction Forum 12 11-26-2008 01:45 PM
