Old 07-08-2011, 05:17 PM   #1
i-trans
Drives: yaris liftback 2007
Hi,
i have try to install this cruise control mod...
But no cruise function...
All switch are okay, i have buy the cc switch, i have connected the switch to the white and the blue wire ( around the purple wire ).
my switch set-up are the same of the tutorial (4 switch with 240, 390 and 910 resistor )
I have buy 2 D3 wire and a A21 connector.
the a21 connector goes to my red wire on my sitch and to the pin1 of the d3 connector.
my black wire goes to pin2 of d3 connector and to the negative.
I start the car, i push on the "on" switch...
at 100Km/h i push on the "set" and nothing happen...
what's wrong?!?
i-trans is offline   Reply With Quote
Old 07-08-2011, 10:34 PM   #2
Originally Posted by i-trans View Post
Hi,
what's wrong?!?
Do you have an AT or MT?
There is no purple wire near the CCS wire in pin 40 of connector A21. Looking at the connector from the wire entry side, there is a blue wire with silver marks next to it on the left and a brown wire next to it in the next row.
Why did you add pins to D3? You only need to do so if using the OEM stalk, not for using the DIY switch method.
Old 07-08-2011, 10:43 PM   #3
i-trans
i have a MT.
this is the reason why i have connect my cc clutch switch on the white and the blue wires (the purple are in the meedle (in the fuse panel under the hood in the conductor side).
why i have connect 2x D3 connector, confusion between 2 diy.....
i go to disconnect the 2x D3 connector, and go to test!
the voltage was okay on my 4 cc switch (12v. when ignition are on).
the 2x D3 connector was my error, it was possible to theses connector cause the malfunction?
**sorry i'm very bad in english**
Old 07-08-2011, 10:52 PM   #4
i have a MT.
OK. That makes more sense.
Being connected to D3 shouldn't cause issues, except that if you are relying on that for the ground of the second wire, it will just be floating, since the other end of the connector is not connected. On you switch array, one side goes to A21-40 and the other to ground.
Old 07-08-2011, 11:04 PM   #5
i-trans
i have disconnected the 2 D3 wire.
I have make a road test and it was unsuccessful
it's the second day i try to make it come true.
this morning i have buy 4 new switch, re-install, re-soldering etc...
i have try with my ccclutch switch and with a jumper...
i have 12v when i put my ignition on, and 0 when it off.
and my "on" button was 1 red wire go to A21 pin 40, and the other to the kick panel (ground).
when i press "set" "resume" or "cancel" the voltage is flickering between 12 and 0v for 1 sec. approx.
i don't know what is the problem at this time...
Old 07-08-2011, 11:08 PM   #6
Can you post a pic of your switch/resistor wiring?
Old 07-08-2011, 11:09 PM   #7
i-trans
give me 2 minutes and i will post!
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
