Old 07-10-2011, 02:32 PM   #1
Grantstead
Drives: '07 white hatchback.
When I removed the headlight, I made sure to peer inside at the reflector. Other than being bent a little out of place, it was the same as the other. Both were screwed in place, and both looked the same (once I bent the offending reflector back into position - to no avail, as the left-side high beam still functions as before). Though if you look closely, you can see what I mean by the left reflector appearing to be a bit longer. The stems on both are straight, too.
I just took a few pictures...you can tell I'd already popped the hood when I took the front view pictures.
Right-side headlight:
Front view: http://img.photobucket.com/albums/v2...o/SANY0027.jpg
Side view: http://img.photobucket.com/albums/v2...o/SANY0031.jpg
Alternate view: http://img.photobucket.com/albums/v2...o/SANY0028.jpg
Left-side headlight:
Front view: http://img.photobucket.com/albums/v2...o/SANY0026.jpg
Sorta-Side view: http://img.photobucket.com/albums/v2...o/SANY0030.jpg
Alternate view: http://img.photobucket.com/albums/v2...o/SANY0029.jpg
Grantstead is offline   Reply With Quote
Old 07-10-2011, 02:54 PM   #2
an you take pics of the actual wire connections to the bulb sockets and of where those red wires connect to the stock wires?
Solar powered High Bright LED lights replacing the fog lights alan1828 Canada 10 05-14-2010 12:34 AM
headlight problem kenkyd Cosmetic Modifications (Exterior/Interior) 2 02-12-2010 06:55 PM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 08:11 PM
Re-did lights, fixed scratch, RR floor mats! lots-o-pics dg4rez Photo-Video-Media Gallery 15 04-21-2009 01:45 AM
JUST GOT MY JDM TAIL LIGHTS!!!!! falkor_99 Cosmetic Modifications (Exterior/Interior) 12 10-01-2007 11:25 AM
