Old 07-17-2011, 06:38 AM   #13
Strider
Drives: 2010 Blaze Blue 4-door Hatch
Okay so I am in the same boat/place with the install as chexmix.
1) from the switch there are 4 wires, but the two reds are spliced together under the plastic flex conduit. So there is no outside red wire and at the end of the spliced together red wire, there is a gray plastic cylidrical connector of some sort. Are we suppose to de-splice the two reds and extend them out for the new steps 6 & 7? And when connecting to pin 3 & 13 we cut the current wires and splice into them (solder the wires together) I assume?
2) Also where would you recommend mounting the switch in a '10 4-door HB? I wanted it in front of the e-brake lever where there are 3 empty spots (there is a door lock switch in one of the four) but the switch is too small and sits too deep.
.... or is there a newer switch with the right wirng and size?
Thanks Guys.
Strider is offline   Reply With Quote
HELP!!, HOW TO INSTALL FOGLIGHT YARIS SEDAN?? shangapol DIY / Maintenance / Service 12 11-28-2012 12:53 PM
Stock/aftermarket Foglight Question? Yaris4L1fe Cosmetic Modifications (Exterior/Interior) 19 06-23-2011 06:47 AM
Question about installing projector fog lights Terra DIY / Maintenance / Service 3 06-15-2011 02:29 PM
FS: Foglight Switch including Relay AzNguy Items for Sale by private party 4 10-19-2009 11:04 PM
WTB: 06 Hatch Foglight Covers (non foglight) hasher22 Willing to Buy by private party 2 06-24-2009 12:35 AM
