Old 07-18-2011, 02:51 PM   #1
PROX4x4
1.5 or 2.5 both=0-60 in 8
Drives: 08 Toyota Yaris
No. Jumping 3 to 4 turns the fog lights on.
The LED needs to be connected to the illumination circuit. If you connect it to the fog light switching circuit, the LED will remain on all the time (even when the ignition is off). If you look at the attached document, which I recently put together for the MI fog light kit, it shows where to connect the LED to the connector for the lighting for the AT shift lever (the feed is present on both AT and MT cars). The green wire is + and the white is -. By using this feed for the LED, it will only light when the headlight switch is on and will dim with the other interior lights when you adjust the dimmer rheostat.
Thanks! now that makes sense, I don't know why those manuals from after market foglights call for splitting pin#3 and switching the two pieces while the other end is open?.
Can i get the illumination power from under the dash? as I am planing on installing the switch where you have installed yours.
PROX4x4 is offline   Reply With Quote
Old 07-18-2011, 03:18 PM   #2
For the LED power, under the dash you can use the dimmer rheostat connector. The light green wire is - and the brown wire is +.
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 02:18 PM
Looking for the Toyota Fog Light install RocknRollRon DIY / Maintenance / Service 33 06-13-2010 07:46 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 11:42 AM
Before I start calling around: fog light install prices St_G Cosmetic Modifications (Exterior/Interior) 4 03-17-2007 10:45 AM
Finally installed oem ebay fog light for hatchback Adriaan General Yaris / Vitz Discussion 6 12-27-2006 05:24 PM
