Old 07-20-2011, 10:36 AM   #1
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Try closing the passenger one and see if the driver's side one starts blowing or perhaps some debris or a critter come popping out.
I will try that and let you know.
I think it's strange though how the centre duct can have two separate temps even though they come from a single duct ... lol.
devinlamothe is offline   Reply With Quote
Old 07-20-2011, 10:49 AM   #2
Exactly - That's why I suspect a critter making its home in there.
Old 07-20-2011, 06:00 PM   #3
devinlamothe
So I did what you said and I even took my dash apart and looked inside and nothing was there blocking anything. Checked all the mechanical actuators to make sure the doors were opening when I changed the settings and they worked too.
Could it be I just need a recharge? Never had one done before.
Old 07-20-2011, 08:34 PM   #4
Maybe. Usually when it needs to be charged, the output never gets cold. It seems odd that the center and passenger side are blowing cold.
Old 07-21-2011, 08:14 AM   #5
devinlamothe
Well now it's working again. After taking the dash apart and checking everything, I put everything back together and was like hmm I will check the H and L ports on the AC lines. The H cap was kind of loose so I tightened it. Also, I checked the AC temp monitor on the front bumper and it had fallen off the mount, so I used some zip ties and put it back.
For some reason one of those things fixed the issue. I now have mostly the same temp from all vents.
Old 07-21-2011, 04:49 PM   #6
devinlamothe
OK now today it's not working again. The drivers sides never get cold while the passenger side gets cool but not as cold as it should be.
I'm thinking it just needs to be recharged.
EDIT: Just an update, I checked the 'sight glass' on my AC and its bubbling like mad so yeah, low on refrigerant. Time to recharge!!
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
A/C or Heater Core leaking into passenger floor? The Shape DIY / Maintenance / Service 3 03-23-2015 12:40 AM
Switched Power Behind Passenger Side Glove Boxes? IsLNdbOi DIY / Maintenance / Service 10 07-05-2011 08:25 PM
Replacing Passenger Side Mirror thorcor06 DIY / Maintenance / Service 4 09-03-2010 12:10 AM
Passenger side airbag question rizaydog In Car Entertainment + Electronics (audio / video / alarm) 0 01-03-2009 07:54 PM
