![]() Drives: Toyota IST - Urban Cruiser Join Date: Jul 2011
Hi Scott,
Yes, the technicians checked the fuel line pressure. They installed a pressure gauge in between the fuel line and the engine and they turned on the Fuel Pump using the terminal hooked to OBD2 port. As soon as we turned on the pump, pressure increased to 3.3. then after 5 minutes it came down to 2.8. And then we waited for 1 hour and it was 2.2. Is it normal? Technicians said it is normal. But before I change the pressure regulator, pressure drastically dropped to 1.0. Thats why they suggested to replace the fuel pressure regulator. Please advise.
#2 | |
Well..the issue is, when you try to turn on the engine after 5 minutes of turning off the engine - it struggles to start. I wish if can show you all this. :P . Just curious to know..Is there any non-return fuel valve available in the fuel pump? Is it exists, maybe fuel is leaking from there..But I'm worried as I witnessed the fuel line pressure back at the garage and it looked fine. Yesterday I drove the vehicle for 100Km and didnt experience any unusual issues. It has done 14Km/L. I wish if I have a tool to observe the fuel line pressure back at home. My gut feeling is fuel line pressure is dropping due to some reason...
#4 | |
| Tags |
| delay, engine start, fuel pump |
| slight clutch kickback after engine start?? | marcus | DIY / Maintenance / Service | 0 | 09-17-2010 11:06 AM |
| boutton Engine Start | yarismo | Cosmetic Modifications (Exterior/Interior) | 22 | 04-19-2010 02:44 PM |
| Installing a start engine button | yarismo | Performance Modifications | 2 | 03-25-2010 07:54 AM |
| Toyota Delays | Buckethead | General Yaris / Vitz Discussion | 3 | 08-26-2006 03:16 AM |
