Old 10-26-2009, 09:28 AM   #1
yarismo
yarismo's Avatar
Drives: Yaris HB luna
boutton Engine Start
hi, I am trying to install an "Engine Start" button on my Yaris HB, but I don't know how to remove the steering wheel cover, and the wiring method..please help
thnx ! شكرا
yarismo is offline   Reply With Quote
Old 10-26-2009, 04:23 PM   #2
Did you buy the complete OEM kit, or one of the ebay kits?
Old 10-27-2009, 10:13 AM   #3
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Where can one buy the complete OEM kit?
Old 10-27-2009, 10:26 AM   #4
I don't think you can actually buy it as a kit, but you could purchase all of the OEM parts needed.
Old 10-27-2009, 12:05 PM   #5
schleppy
I love momentum.
schleppy's Avatar
Part numbers? :D
Old 10-27-2009, 12:42 PM   #6
Part numbers? :D
Too many to dig through the EPC to list. The list includes the push button switch, solenoid for the steering lock, ECU and receiver for the smart card, etc.
All of which would have to be imported from another market.
Old 10-27-2009, 02:17 PM   #7
Sparks Toyota-TRD
Drives: Toyota/Scion
Send me your email and I can get you the information you are looking for!
Tim
Sparks Toyota-TRD is offline   Reply With Quote
Old 10-27-2009, 03:16 PM   #8
1NZYaris1
1NZYaris1's Avatar
How about this
Chrome gear knob, enhanced with engine starter button. Once installed you simply turn your key to on position and press the starter button on the gear knob to fire up your engine.
Universal fit, supplied with all wiring and relay box required for installation on a 12 volt negative earth vehicle. Also includes a range of adaptors to suit most gear shift shafts.
Old 10-27-2009, 09:10 PM   #9
Tim
Tim,
Can you order parts for other markets?
Old 10-28-2009, 11:35 AM   #10
Sparks Toyota-TRD
I unfortunately cannot get parts from other markets, but I can give you guys the How-To's on removing the interior. :D
Tim
Old 10-28-2009, 02:27 PM   #11
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
push button starts are normally a split in between the starter wire so if you can llok for a wire refrence guide to find starter wires thats how i wired my s2000 push button start
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-28-2009, 03:08 PM   #12
yarismo
yarismo's Avatar
can anyone post some pictures on how to do the wiring for that button?
Old 10-28-2009, 03:23 PM   #13
We need some more information to help you.
Did you buy just the button, or is it a kit that also includes one or more relays?
Did you receive any documentation with the button?
Old 10-28-2009, 03:37 PM   #14
yarismo
yarismo's Avatar
actually, I have only the button, no documentation.
I wanna make a general idea about what I will find under the cover and the wiring before I open it!
Old 10-28-2009, 03:46 PM   #15
OK. If it is just the button and you don't want to open the package yet, can you tell how many wires come out of the switch?
If the switch is just a momentary switch, then you could just hook it up between the gray wire in pin 5 and the black wire in pin 7 of the keyswitch connector. The only problem would be if you accidentally hit the switch once it was running, you would grind the starter.
Old 10-28-2009, 03:48 PM   #16
THE ONE
ドン フアン
THE ONE's Avatar
Drives: Yaris coming really soon... :)
Send a message via MSN to THE ONE
OK, I don't know if this helps, but anyway... I found this cool site where they have a lot of DIY's, and one of those tells you how to install the ingnition button step by step, with pics and everithing.
http://www.instructables.com/id/Push...-for-your-Car/
Hope it is of some use...
*NOTE: You still have to use your keys to start your car.
THE ONE is offline   Reply With Quote
Old 10-28-2009, 04:13 PM   #17
yarismo
yarismo's Avatar
the link you gave doesn't work for me !!!
* the "cover" that I mean is not the package, I mean the plastic parts that covers the steering wheel
Old 10-28-2009, 04:16 PM   #18
That link is really not directly applicable. Can you snap a picture of the back of the switch with the wires and of any documentation that came with it?
yaris won't start, engine truns over but won't start. zara616 General Yaris / Vitz Discussion 16 09-05-2021 11:39 AM
Rough engine start w/76? guyver408 DIY / Maintenance / Service 12 06-26-2009 12:18 AM
