Old 06-22-2009, 02:53 AM   #1
guyver408
Drives: 2009 Yaris 5dr
Rough engine start w/76?
I have a 2009 Hatchback - 6mo old. This morning had a rough engine start (cranked engine, seemed to hesistate before turning over) - this has not happened before.
Day before I filled up w/76 brand gasoline (standard octane) - I've previously only filled up w/Chevron. I also reset maintenance light (changed oil a few weeks ago).
Do you think it was gas difference, or something I need to watch?
guyver408 is offline   Reply With Quote
Old 06-22-2009, 06:57 AM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Hesitating BEFORE cranking over isn't bad gas. I wonder if your battery's on its way out?
Old 06-22-2009, 08:21 AM   #3
try turning it to ACC, wait couple seconds before cranking??
Old 06-23-2009, 12:19 AM   #4
guyver408
forgot to mention - the hesitation has not happened again - only the one time.
Old 06-23-2009, 12:30 AM   #5
Brian
Brian's Avatar
Is it when you crank it and it continues to try and start for a second or two like your holding
the key but you have actually let go then after 1 or 2 seconds it starts. If so, I've had this problem and
so have a couple other members. Its nothing to worry about.
Old 06-23-2009, 02:20 AM   #6
guyver408
Brian, that's exactly what happened. Relieved that it's no issue.
Any idea on the cause of it?
Old 06-23-2009, 07:54 AM   #7
Brian
Brian's Avatar
I have no idea what causes it. It happens about once every 6 months to me. No one
that I know of has had any negative effects from this though.
Old 06-23-2009, 08:04 AM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
had the weather changed at all? if you've had the car 6 months you've likely not experienced an entire season of weather yet.
my car sometimes does not appreciate high humidity. then again my engine is on it's way out anyway.
Old 06-25-2009, 11:10 AM   #9
twowheels
Drives: '09 Meteorite Metallic 3 dr MT
I didn't see your thread when I posted mine, but I'm having the same experience now and then:
http://www.yarisworld.com/forums/showthread.php?t=19409
twowheels is offline   Reply With Quote
Old 06-25-2009, 11:12 AM   #10
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
76 octane???
thats more than a tad lower than what is needed.
the standard fuel around here is 87 octane.
Old 06-25-2009, 11:42 AM   #11
Brian
Brian's Avatar
I think he meant the gas station 76
Old 06-25-2009, 04:17 PM   #12
the slow cranking issue.. i've had it, 3 days in a row until i changed my start up habit. I don't know what could have caused it as i used it the same for a whole year when it happened.
Old 06-26-2009, 12:18 AM   #13
guyver408
Thanks for the input folks. Problem has not happened again - just that once.
Also found old post on same problem http://www.yarisworld.com/forums/showthread.php?t=12167.
yaris won't start, engine truns over but won't start. zara616 General Yaris / Vitz Discussion 16 09-05-2021 11:39 AM
Engine Slow to Start ruimond DIY / Maintenance / Service 26 04-24-2021 02:37 PM
Is the Yaris engine a little rough? thomasward00 General Yaris / Vitz Discussion 23 04-30-2007 12:17 PM
