Old 07-21-2011, 04:44 AM   #1
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
Guys: Tell me about the oil cooler radiator for automatic transmissions.
If it exists, and how it can be cleaned from the inside?
MickZEL is offline   Reply With Quote
Old 07-21-2011, 06:24 AM   #2
On AT Yaris the bottom part of the radiator is an oil cooler. There are two hoses that go from the transmission to it. The clean it you flush it with fresh transmission fluid.
Old 07-21-2011, 11:06 AM   #3
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
New liquid for washing is expensive.
Can be washed than deshovaya? Kerosene or petrol for example, after the blow compressed air?
Old 07-21-2011, 11:12 AM   #4
The ATF fluid is expensive, but I would not want to risk residue from other fluids. To save money I would only use a cheaper, but similar ATF fluid for flushing it.
Old 07-21-2011, 12:43 PM   #5
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
What could be the equivalents ATF ?
Old 07-21-2011, 01:06 PM   #6
According to Toyota ATF WS is unique, but for flushing you could use a Dexron III or Dexron IV ATF, and if a few drops of residue remained it wouldn't be a problem.
Problem with my car rakhan01 DIY / Maintenance / Service 8 12-03-2010 05:12 AM
Toyota C160 Reverse Gear Problem Parmas DIY / Maintenance / Service 2 12-01-2010 01:30 AM
Problem Starting Car drunkwithwords General Yaris / Vitz Discussion 3 07-21-2010 04:01 PM
Yaris Central Locking Problem pbasuita UK 0 07-10-2010 03:46 AM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 08:11 PM
