Old 07-21-2011, 05:14 PM   #1
Jason@SportsCar
Originally Posted by OTB View Post
So I'd appreciate your input on this subject, and especially those of you who took the turbo plunge.
My goal: a reliable lightweight car for street transportation that will still give cooper S cars a run for their money in street class time attack. I have a MR-S race car, and don't have intentions of making my street car into a very competitive car. I do, however have a goal of making it road course worthy (preventing oil and fuel starvation, coolant overtemps, brake fade.)
I own: 2007 Yaris USA 3-door with no options, good quality springs, struts/shocks, rear swaybar. I have owned some much "nicer" cars in my day, but I'd have to say this is probably the best street car I've owned. It is a blast to drive, but obviously with a couple limitations. 1) power-I don't need a ton of it, but it doesn't even have enough power to maintain throttle through corners on the track. 2)suspension-front strut tower mounting (or lack thereof) and the rear end "is what it is"
I used to own a turbo cooper s (stock with good suspension) that my buddy and I would both drive in different time attack events, and we did ok. The car was lots of fun, surprisingly strong, and a pain to work on. I unfortunately had a incident with a couple deer and no more cooper.
My question is....to meet my goals above, do I pursue another cooper, or make the yaris a better weapon?
Proposed Yaris plan: Zage turbo kit to produce approx 150hp for some reliability. I think most guys tune for more boost/power than that, but I'm not interested in pushing the limits of tuning and 1nz strength. Better suspension (have custom lower than MI springs made for my tokico reds, or go to damping adjustable coilovers). Limited slip. I bought my Yaris as a salvage (but actually tip top, just a front bumper cover replacement really) for a good price. Zage kit + management (FIC and PnP harness) + tuning + monitoring gauges + lsd+unplanned BS in reality will cost about $4500. Do I have to kiss my front and rear oem brakes goodbye?
Potential other cars: another turbo mini, rsx-s (great setup but hard to find one that some kid hasn't turned into a shitmobile), and I just can't stand the mazdaspeed 3 so don't even go there. If there was an Abarth 500 for sale in the US, I would probably just get one. Turbo cobalt is a real performance car, but heavy....everything is so heavy nowadays. I'm a Colin Chapman kind of guy. All of my other options weigh 300+lbs more than the Yaris.
Back to the question-could the boosted and sorted 1nz Yaris fit my goals (and do it at 1000's less than a used turbo mini)? Would I be able to carefully setup and tune the car, then mostly just perform maintenance, not a never-ending research project?
Thanks for your input!!!
Only you know what will make you happy... But I would start with the basics and work up.
First, better suspension. Get a set of quality coil-overs. The Tokicos are not track worthy, they are an OK street shock - hint, stay away from any adjustable shock that combines compression and rebound adjustments, you will never get the damping curve where you want it. Stick with rebound adjustable shocks unless you really know what you are doing, you can really screw up a car playing with the compression settings.
Swaybars: if you get the springs and shocks right you wont need to bolt a 15lb weight to your rear axle.
Brakes: the stock brakes are overkill for the weight of the Yaris. Upgrade the front pads and leave the rest alone. If your car has a lot of miles, or the lines look suspect, get the stainless ones. We only added brake cooling ducts when we went to the 13" wheels because the airflow is so restricted, we have still never had fade - and this is with a 40min race, not a few hot laps.
Trans: this makes the car, you must get an LSD. If you have the money get the OS Giken, if you want to go cheaper get the TRD unit. BUT while you are in there install the xB 4.312 final drive, it really wakes the car up. You will already be paying the labor (or doing the work) to pull the stock gears when you install the LSD, it is not much more work to swap the gears.
Tires/wheels: 13" wheels make the car a rocket. They give you an even shorter final drive, lower the cg (and help get the roof down out of the air), they are also a lot lighter than the big stuff. Another advantage is you can run a wide 13" tire without it bashing the fenders, no need to cut or roll.
Bolt-ons: Get the header, intake and ecu. You can really unlock some power.
That alone should be enough to take out any stockish Cooper S. If you are not satisfied at that point you have all the basics covered, and now you add the FI.
As far as a radiator, the Mishimoto xB unit pretty much drops right in (you have to drill two holes in the core support), and we used the xB hose set.
Old 07-21-2011, 06:11 PM   #2
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Just in time
Old 07-21-2011, 06:13 PM   #3
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
I have seen more than a few Abarths here in SC ...
Old 07-21-2011, 06:25 PM   #4
Jason@SportsCar
They are all over the place... It takes more than a set of stickers to make a car a model that is not sold here. Yet. There are certainly "tribute" cars out there. Fiat even lets you order the 500 with some stickers.
Old 08-16-2011, 07:13 PM   #5
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Yeah , I didn't get fooled by a set of stickers on a Yaris .
On second thought maybe I was suffering from heat induced delusions on that particular day . I was fishing all day and the sun was brutal . Maybe that wasn't a couple Chrysler Execs that I had a conversation with . You are probably right ., it was just some older guys who who decided to "rice up" ( or maybe the term should be "linguini up" , since it is Italian ) their Fiat 500's with some stupid little scorpion hood emblems . Maybe I was hearing things when they said there were 4 Abarths ( I have only seen 3, and to be honest maybe the third Abarth was just a plain 500 , it was a good distance away ) in Myrtle Beach , South Carolina.
Seriously Jason , with your vast experience with cars you have never heard or seen or known anyone that has driven new car models on public roads before they went on sale here in the USA ?
Old 08-16-2011, 07:35 PM   #6
Jason@SportsCar
Only took you about month to come up with a reply. Yes, it happens all the time with prototypes, I drove the 370Z the week before its launch at the LA autoshow, and I just got done driving one of the six 2012 pre-produciton Yaris that are in the US.
Seeing a pre-production car on the road and saying "I have seen more than a few Abarths here in SC" is a bit of a stretch in the context you put it - as if to bait the OP into thinking the cars are here.
But its great that you ran into a couple of guys from Detroit driving a Mexican built Italian car. Can't wait to see what a production Abarth offers when it actually makes it to our shores.
Old 08-17-2011, 01:04 AM   #7
OTB
OTB's Avatar
Drives: 2zz MR-2 Spyder
gearing
so all what-not aside, would it be a valuable resource if the xb final drive posts were stickied in a good place?
OTB is offline   Reply With Quote
Old 07-22-2011, 03:33 PM   #8
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
what ECU are we to use for just BOLT-ONS???
ROCKLANDTOYOTA is offline   Reply With Quote
Old 07-22-2011, 03:49 PM   #9
Jason@SportsCar
Anything that will let you past the rev limiter, and control the VVTi.
We had a custom harness made that allows us to piggy back an AEM EMS series 2.
There are other options out there, none of which are cheap. But without ECU control any mods, including FI, are compromised.
Old 07-22-2011, 07:21 PM   #10
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Good advice was given for sure. If you go boost, keep it at a 40whp gain and no more if you want it reliable on a stock motor for track abuse. I say 40whp gain instead of a specific number because dynos vary. Get a baseline number, and use that same dyno later for reference. I popped rods many times at 150whp (our dyno) and it is never fun to invest $500 entry fee and go home on a tow truck. I must have done 6 Time Attacks at 130whp and never had issues. It was enough power to podium many times in street fwd, as long as you are a decent driver and you have everything else dialed in.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 07-25-2011, 01:11 AM   #11
OTB
OTB's Avatar
thanks! I think alot of us wanted this info
Old 08-02-2011, 12:56 PM   #12
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
What parts would have to be swapped out for this? I'm assuming that it's not just the drive/driven pair for 5th gear (circled in red), but a different gear that mates to the LSD or driveshafts? I'm having a hard time getting a good picture of the gearbox from these parts diagrams.
Looking at the C50 repair manual gives much better illustrations, so I'm thinking it's actually the gear that attaches to the differential? If so, then wouldn't the entire output shaft also have to be replaced?
Old 08-03-2011, 12:05 AM   #13
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Yes.
Persuade me to buy a Yaris! TONIZZLE General Yaris / Vitz Discussion 48 09-09-2011 11:31 AM
Why does the wind move my Yaris HB all over the highway? Syroyizhka General Yaris / Vitz Discussion 19 12-29-2010 03:41 PM
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 05:06 PM
