Old 04-05-2009, 02:47 PM   #1
Syroyizhka
Syroyizhka's Avatar
Drives: 2007 Yaris Hatchback
Question Why does the wind move my Yaris HB all over the highway?
I haven't really went on the highway much, but one day i did, and i was going only 60 mph and my yaris was moving 3 feet back and forth like crazy, i bought it with lowered suspension and i thought that would make it more stable, and the car looks very airo dynamic, so i've been told. So, is it my alligmnent, tire pressure? any other components that are damaged? And NO, the wheels are not loose, i tightened all the bolts
Syroyizhka is offline   Reply With Quote
Old 04-05-2009, 03:18 PM   #2
OK Yaris
Drives: 2007 Liftback
I would have the alignment checked. I drive in mid-high crosswinds just about every day and the car definitely doesn't move around that much. Stock suspension with 15" Konig Helium and General Altimax HP factory size tires here.
What suspension/wheels/tires are you running and how much tire pressure?
OK Yaris is offline   Reply With Quote
Old 04-05-2009, 03:19 PM   #3
41magmag41
Drives: Loaded 2007 mica silver sedan
Try checking your air pressure on the tires. If you have them over inflated this could cause you to be blown around. Learn to accept the fact that with a side wind you will have to stay on top of the yaris. Also have your alignment checked as that could cause you to wander.
41magmag41 is offline   Reply With Quote
Old 04-05-2009, 03:23 PM   #4
ddongbap
I swear theres a post about this every single month.
Old 04-05-2009, 03:25 PM   #5
Syroyizhka
Syroyizhka's Avatar
whats the proper air pressure supposed to be?
Old 04-05-2009, 03:39 PM   #6
tomato
tomato's Avatar
Could be because the first time you feel the wind toss the little Yaris around, you feel like you're going to meet your maker and you need all the you can get?
Windy situations sure make a good case for dropping the car a bit.
3 feet, though, that seems like a lot. There are some good threads here, search for "wind"
Good luck .
Old 04-05-2009, 03:42 PM   #7
ddongbap
Good luck .
Yea, makes sense. I totally agree with you. But doesn't it seem like theres tons of these posts?
Old 04-05-2009, 03:49 PM   #8
Kal-El
Kal-El's Avatar
Can the Mods start merging all these multiple threads that keep popping up over and over?? I don't recall ever seeing one merged and this topic is one example of one that get's a new thread every week.
But to prevent the need for this, let's please use the search function!
Old 04-05-2009, 03:55 PM   #9
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Which makes me wonder why you take the trouble to respond
Old 04-05-2009, 05:43 PM   #10
Ryu
The proper tire pressure is 32 PSI.
Old 04-05-2009, 08:09 PM   #11
tomato
tomato's Avatar
That's true too. Maybe we should have a sticky "Yaris in the wind and suggestions for improvements" or something like that?
Old 04-05-2009, 11:48 PM   #12
ddongbap
To point it out. You really couldn't figure that out?
Old 04-06-2009, 12:12 AM   #13
ddongbap
good one
I mean, DUHHHHHHHHHHHHHH, right?
But I get his shick anyways. Hes just trying to be a smartass. But I'm a higher level smartass than him, so it won't work.
Old 04-06-2009, 12:43 AM   #14
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
welcome to my club
Yawesh is offline   Reply With Quote
Old 12-20-2010, 03:33 PM   #15
swidd
Drives: Yaris HB
In the Yaris, you can go sailing and driving at the same time!
Old 12-20-2010, 04:31 PM   #16
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Get a rear swaybar
Also, is there way to get a huge search button to pop-up on screen in certain sections when you hit "Post new thread"? Let's have it look like this:
Old 12-20-2010, 06:42 PM   #17
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Zombie thread
Old 12-20-2010, 08:07 PM   #18
teddy
Drives: 2008 5-door hatchback
Send a message via MSN to teddy
Well since this zombie thread has been brought back and I was just thinking about this the other day anyway I might as well ask.
Will the rear sway bar actually help with this? It isn't normally very bad, but I can definitely feel the wind on a breezy day.
teddy is offline   Reply With Quote
highway shaking
Not sure where to start (2009 yaris)... Faith87 General Yaris / Vitz Discussion 37 03-23-2009 05:35 PM
