Old 07-26-2011, 08:49 AM   #1
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Actually I have a quick question for those of you who know about AC systems.
Do I have to replace the drier at the same time as the line? I'm getting conflicting answers saying it you change any part you should replace the drier at the same time to prevent any moisture in the system, but I don't know.
devinlamothe is offline   Reply With Quote
Old 07-26-2011, 09:43 AM   #2
The general rule of thumb with A/C is that you do replace the drier when replacing parts on a leaking system, but considering that yours still had some freon in it (i.e. did not completely vent), you would be safe with not replacing it.
Old 07-26-2011, 09:54 AM   #3
devinlamothe
Well when I replace the liquid line I'm going to have to have the entire system evacuated aren't I? I don't want to have any of the 134a vent to the atmosphere.
I ordered a replacement drier desiccant bag anyways (I think it was $28).
Old 07-26-2011, 09:57 AM   #4
Correct. It will have to be evacuated before replacing the part, and then again once the part is on to remove any particulate and moisture.
Old 07-26-2011, 10:02 AM   #5
devinlamothe
Alright good. Glad I ordered a replacement then.
Hoping I can get the replacement line in a couple of weeks because August is going to be hot.
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
A/C or Heater Core leaking into passenger floor? The Shape DIY / Maintenance / Service 3 03-23-2015 12:40 AM
Switched Power Behind Passenger Side Glove Boxes? IsLNdbOi DIY / Maintenance / Service 10 07-05-2011 08:25 PM
Replacing Passenger Side Mirror thorcor06 DIY / Maintenance / Service 4 09-03-2010 12:10 AM
Passenger side airbag question rizaydog In Car Entertainment + Electronics (audio / video / alarm) 0 01-03-2009 07:54 PM
