Old 07-29-2011, 10:45 AM   #1
06yarishb
Drives: 2012 Yaris HB LE
no cigar...after I ground the pin#3 the light from the fog switch is on when I turn on my headlights but when I push to turn on the fog the light on switch turn off. Also I just found out my left signals are not working...where is the fuse for that? May I blew the fuse somehow..I checked the bulbs front and back they look fine...can\t find the fuse for the signal lights. :(
06yarishb is offline   Reply With Quote
Old 07-29-2011, 11:12 AM   #2
They both operate off of the 10A HAZ fuse (in the under hood fuse panel). If that fuse is blown then neither should work.
Fog Light Installation chrisj Cosmetic Modifications (Exterior/Interior) 39 03-12-2011 11:08 AM
Has anyone tried taping into the parking lights for fog light installation (safe?) YarisSedan DIY / Maintenance / Service 14 03-20-2010 04:49 AM
2009 HB fog light installation rbell DIY / Maintenance / Service 3 06-17-2009 09:16 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
