Old 07-29-2011, 05:09 PM   #1
Lil Abner
Drives: 2009 3dr LB Manual
Well, I know if the "ON" pulse isn't long enough, the motor will stick. Looking at your schematic, R4 and C2 control your "ON" pulse. The equation for time is:
T(on)=0.7*R*C
R4=10K ohms, C2=100uF=0.0001F
T(on)=0.7*10,000*0.0001
T(on)=0.7 sec
The only think I can think of is replacing R4 with a resistor around 14.7K or 15K. That would give about 1 second. Or just try that equation out and see.
Since you have the wires taken apart, you could also try this. Turn the wipers on low (not delay), and leave the wires disconnected. Quickly jump the blue wires together, and quickly disconnect. Try doing that slightly longer each time, until the wipers work properly. What you're trying to determine is the required ON pulse length needed by your module.
When I did my module, I only worried about the rear wiper, so I don't have any timing numbers for the front.
So you got the EWD for that switch? I'd hope it's simple, like you're saying, to just supply a ground and/or positive to one or all of those 3 little pins on the larger plug!
Old 07-29-2011, 08:31 PM   #2
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
T(on)=0.7*R*C
T(on)=0.7 sec
Hey lil'abner, thanks for your suggestions. I actually tried using both the module and simulated ON pulses by hand (shorting the wires with different delays) and the wiper arm position remained in odd positions whenever I interrupted the connection.
No, lol. I was looking at the EWD of the OEM wiper switch.
-toy
Removing rear wiper fred812 Cosmetic Modifications (Exterior/Interior) 34 01-27-2013 12:22 AM
Slight mod to rear NickNickNick Cosmetic Modifications (Exterior/Interior) 4 05-11-2006 01:03 AM
