#1 | |
2ZR swap. DO IT! Ask how!
I'm also guessing that the signal is 12V, so you'd have to use a regulator or voltage divider to get down to the 5V input that the F/V chip is expecting. I'm still looking through the datasheet to see exactly how the F/V converter works. Any suggestions on what kind of comparator would be the right type to use? |
#2 | |
For the comparator, a general purpose one, like the LT1011 would be fine. It is amazing how much more complicated this gets trying to do it with analog, rather than digital. I should just build you up one to experiment with using a microcontroller. I could make a simple little black box that connects to ignition switched power and then has an output to drive the relay coil. I could have a pot on the box to adjust the switch over speed.
#3 | ||
I looked at the EWD and the power steering is already throttled by the ECU based on speed and the torque sensor. According to p 176 of the EWD: Quote:
I like elec power steering. It rocked in my RX-8, made it one of the most pleasurable cars to autox - past cars I raced with traditional systems always struggled to keep up, our Corvette use to puke power steering parts regularly.
![]() I think the system in the Yaris works great. In the GT/B-Spec cars it works seamlessly, I had no problem on the track with it. I hated the H Prod car when we first started racing it... Due to some hacked wiring the system never worked, and with a 10" wide slick the car was a beast, always fighting you in the turns. However, with time we were able to work out some of the steering bind, making it easier to drive. Ditching the elec motor and the stock column made it much easier to turn (still not as good as the EPS system), and it actually dropped a good bit of weight. No brainier for me, in a street car I would keep it.
#5 | |
It actually sounds like it is better for track than street. The primary complaint about the EPS is how it induces wander at highway speed.
#6 | |
I just mean based on the overall number of components and the little bit of math required for configuring the comparator, etc. The P/S light id turned on by the combination meter when the EPS reports an issue. If the EPS isn't alive it can't complain.
Understood. For an entry level EE student like me, the more cost effective solution would be using components and a breadboard instead of a PLD. Most of us DIY-ers don't have access to a programmer. The only microcontroller I've been exposed to so far comes on a $150 dev board, and that's a bit too expensive to cloister in a box under the dash. =)
Is the pulse width fixed, or is it always 50% duty cycle? I'm trying to do a PSPICE sim of the F/V converter and need some idea of the settings for the VPULSE component.
It's a 50% duty cycle signal, where the width of the pulse decreases as speed increases. If you need a definite frequency value at a particular speed, let me know, as I have a portable scope.
| Electric power steering | Geoff Peace | DIY / Maintenance / Service | 4 | 04-10-2018 05:28 AM |
| Power Steering Fluid | jstantherprsn | DIY / Maintenance / Service | 8 | 04-05-2016 06:24 PM |
| Power Steering Light | sıɹɐʎ | DIY / Maintenance / Service | 12 | 02-19-2014 07:22 PM |
| URGENT Advice Needed! Relating to Power Steering, Alternator and Electrical. | The Marshall | General Yaris / Vitz Discussion | 25 | 10-21-2010 08:23 PM |
| Can't find power steering reservoir on '10, is there one? | JerseyJeff84 | DIY / Maintenance / Service | 4 | 09-07-2010 10:47 AM |
