Old 08-09-2011, 04:37 PM   #31
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
It is amazing how much more complicated this gets trying to do it with analog, rather than digital.
Why would this be the case? There are a few additional passive components that need to be added around the F/V and comparator, but it seems to be fairly straightforward. Is it a matter of getting a comparator that has enough hysteresis to prevent noise around the switching point from making the output fluctuate? Sorry if those aren't the right terms, I just looked some of this up.
I looked at the EWD and the power steering is already throttled by the ECU based on speed and the torque sensor. According to p 176 of the EWD:
* In order to reduce driver’s steering force, the assist current is calculated from the torque sensor signal and vehicle speed
signal of the meter or CAN communication to output to the motor.
∗ When abnormality occurs in the system, the assist is prohibited by shutting off the power source relay and motor relay in
ECU, and the warning light (P/S) in the meter is lit up.
So if we were to ever crack the ECU, we could in theory change the control algorithm. It seems strange that removing the fuse doesn't turn on the (P/S) light.
Electric power steering Geoff Peace DIY / Maintenance / Service 4 04-10-2018 05:28 AM
Power Steering Fluid jstantherprsn DIY / Maintenance / Service 8 04-05-2016 06:24 PM
Power Steering Light sıɹɐʎ DIY / Maintenance / Service 12 02-19-2014 07:22 PM
URGENT Advice Needed! Relating to Power Steering, Alternator and Electrical. The Marshall General Yaris / Vitz Discussion 25 10-21-2010 08:23 PM
Can't find power steering reservoir on '10, is there one? JerseyJeff84 DIY / Maintenance / Service 4 09-07-2010 10:47 AM
