Old 08-19-2011, 11:57 AM   #1
bad_bwoy007
bad_bwoy007's Avatar
Drives: 2010 8T0 Yaris Liftback
Ok cool. So to add the regular Toyota actuator you can connect it to the open connector under the trunk lid which only opens the lock as if you were using the key.
So you will still need to use the key to close the hatch.
Where can I locate those two wires (gray and pink) under the dash?
So it seems as a mod Yaris owners have two options.
1. Stock key opening actuator.
2. Aftermarket actuator that taps into the existing wires and is linked it into your aftermarket module.
Where can I find some of those spring loaded bump stops?
bad_bwoy007 is offline   Reply With Quote
Old 08-19-2011, 12:17 PM   #2
For unlocking you have the choice of OEM actuator or aftermarket one.
For popping the hatch you need another aftermarket one plus a "trunk popper". Do a google search to find places that sell those. (A1electirc.com sells actuators and may also carry poppers).
The pink and grey wires come into the body ECU (where the under dash fuse panel is) via connector 4A pins 3 (gray) and 4 (pink).
Old 08-22-2011, 09:50 AM   #3
vten
im following this post too ....
I dont need the trunk to pop open ...I just need the capability to lock and unlock it with my aftermarket alarm . are these items all I need to do the task ?
Actuator Assembly, Back Door Lock: 69150-52070
Mounting Bolts: 91511-B0614 (2 required)
thanks guys
Old 08-22-2011, 10:03 AM   #4
thanks guys
Correct
Old 08-24-2011, 05:40 PM   #5
bad_bwoy007
Mounting Poppers
Thanks CTScott,
So I went ahead and ordered the poppers. One question I have is where would be a good place to mount these things.
There are limited areas to put these.
Any ideas?
Another question I have about the stock actuator, does it open and close the trunk, or just open? (Just need to clarify)
Old 08-25-2011, 01:02 AM   #6
Thanks CTScott,
Any ideas?
I think you'll need to do a bit of experimentation before drilling and mounting the poppers. I am not sure where the best location will be for them.
The stock actuator locks and unlocks (you reverse polarity to the actuator to lock/unlock).
Aftermarket Yaris Hatchback / Liftback RS Spoiler bad_bwoy007 General Yaris / Vitz Discussion 7 04-07-2011 03:05 PM
Yaris Liftback Seats artyin General Yaris / Vitz Discussion 3 04-30-2006 04:07 PM
