Old 08-19-2011, 11:57 AM   #8
bad_bwoy007
bad_bwoy007's Avatar
Drives: 2010 8T0 Yaris Liftback
Ok cool. So to add the regular Toyota actuator you can connect it to the open connector under the trunk lid which only opens the lock as if you were using the key.
So you will still need to use the key to close the hatch.
Where can I locate those two wires (gray and pink) under the dash?
So it seems as a mod Yaris owners have two options.
1. Stock key opening actuator.
2. Aftermarket actuator that taps into the existing wires and is linked it into your aftermarket module.
Where can I find some of those spring loaded bump stops?
bad_bwoy007 is offline   Reply With Quote
Aftermarket Yaris Hatchback / Liftback RS Spoiler bad_bwoy007 General Yaris / Vitz Discussion 7 04-07-2011 03:05 PM
Yaris Liftback Seats artyin General Yaris / Vitz Discussion 3 04-30-2006 04:07 PM
