Old 06-03-2011, 11:13 AM   #55
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
1st,
You run lower pressure at the track because you have to allow for heating of the tires.
Tires on the track can get so hot you can't touch them barehanded, hence you eventually build to a higher pressure. So you are still running higher pressure on the track once the tires get up to temp. You usually log track tire temps and the corresponding tire pressures so you know where to start cold.
You should never have this much heat in a street tire obviously, unless severely underinflated, or one is driving in an extremely non street friendly manner.
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 06-03-2011, 12:28 PM   #56
Hershey
Originally Posted by daf62757 View Post
How do you like those tires? I was thinking of getting them when its time replace mine but I have to order them online. There aren't any tire stores that sell them here in Indianapolis.
These make the ride for the sedan better and dry / wet handling as well . Got them for $92 each . As for gas mileage , probably a tad better , if not the same as the Bridgestone RE 92s' . The gas mileage has been over 40 m.p.g. for the last 3 fills . This is an automatic .
Old 06-03-2011, 02:03 PM   #57
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Originally Posted by 1stToyota View Post
You make a good point...running higher psi on the track would probably effect the braking and handling, maybe putting your safety at risk, yes? ...same principles apply for DDing, just to a lesser degree.
definetly, i'm not saying that running high PSI in my DD is increasing grip, i'm definetly reducing it but i'm well in control of the car, tho high speed braking at speeds over 100mph is a little darty...i found that out this morning racing a turbo MX6 on the way to work, haha
Originally Posted by R2D2 View Post
1st,
R2
yes, a good way to prove this is the Indy 500 race this past saturday...the first few laps the cars were throwing sparks until the tires heated up & gained pressure thus raising the ride height of the cars just enough
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 06-03-2011, 02:16 PM   #58
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I rest my case.
-Type 07 FFL-
My odometer 03/11
Old 06-04-2011, 11:21 AM   #59
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Drives: 2013 Yaris 5 dr liftback
Originally Posted by mazilla View Post
Story of your life?
Sorry Goober....must have hit a nerve.
Big Dave
Indianapolis, IN
Synthetic Oil....its in my car.....for at least 10,000 miles!
daf62757 is offline   Reply With Quote
Old 06-04-2011, 12:33 PM   #60
mazilla
advocatus diaboli
mazilla's Avatar
Wow little dave, ur really hitting me hard with these comebacks. What's next, rubber V. Glue references?
-Type 07 FFL-
My odometer 03/11
Old 06-04-2011, 12:53 PM   #61
daf62757
daf62757's Avatar
Against a mental giant such as yourself.....never.
Big Dave
Indianapolis, IN
Old 06-04-2011, 03:09 PM   #62
mazilla
advocatus diaboli
mazilla's Avatar
Flatterer.
-Type 07 FFL-
My odometer 03/11
Old 06-29-2011, 11:29 PM   #63
malibuguy
Obsessed with 1.5L
i just upped my tires to 54psi from 52psi
-96 Tercel 4dr
Old 08-17-2011, 06:43 PM   #64
daf62757
daf62757's Avatar
Could you tell any difference in mileage by increasing it 2psi? I would think the difference couldn't be that much.
Big Dave
Indianapolis, IN
Old 08-18-2011, 12:11 AM   #65
malibuguy
Obsessed with 1.5L
not really, but my drives can vary alot depending on how much traffic i hit.
but i did notice the car noticeably handles better & the stability control doesn't kick in & try to throw me off the road anymore in aggressive corners...maybe something to do with these tires. I won't go any higher tho.
i wasn't expecting much of a change either, go figure.
-96 Tercel 4dr
Old 08-18-2011, 12:27 AM   #66
Hershey
35 p.s.i. for the Continental Pro Contact w/ Eco Plus .
Old 08-19-2011, 01:43 PM   #67
STC
"LibertyRides!"
STC's Avatar
I just changed mine from 40psi to 42psi... I hover around 38 to 42!
Cheers!
~ Mark ~
Best all-season tires for the Yaris? Rahxephon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 03-17-2013 07:40 PM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 07:58 PM
2007 Yaris bad tires weaver615 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-27-2010 08:21 AM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 05:46 PM
