Old 06-03-2011, 01:03 PM   #32
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Originally Posted by 1stToyota View Post
You make a good point...running higher psi on the track would probably effect the braking and handling, maybe putting your safety at risk, yes? ...same principles apply for DDing, just to a lesser degree.
definetly, i'm not saying that running high PSI in my DD is increasing grip, i'm definetly reducing it but i'm well in control of the car, tho high speed braking at speeds over 100mph is a little darty...i found that out this morning racing a turbo MX6 on the way to work, haha
Originally Posted by R2D2 View Post
1st,
You run lower pressure at the track because you have to allow for heating of the tires.
Tires on the track can get so hot you can't touch them barehanded, hence you eventually build to a higher pressure. So you are still running higher pressure on the track once the tires get up to temp. You usually log track tire temps and the corresponding tire pressures so you know where to start cold.
You should never have this much heat in a street tire obviously, unless severely underinflated, or one is driving in an extremely non street friendly manner.
R2
yes, a good way to prove this is the Indy 500 race this past saturday...the first few laps the cars were throwing sparks until the tires heated up & gained pressure thus raising the ride height of the cars just enough
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Best all-season tires for the Yaris? Rahxephon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 03-17-2013 06:40 PM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
2007 Yaris bad tires weaver615 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-27-2010 07:21 AM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
