#1 | |
![]() ![]() Drives: 2011 yaris rs Join Date: Nov 2010
Just curious, did your gas mileage improve after that 1st tank went down?
0-60 IN UNDER FIVE
Drives: 2008 Blk on Blk Yaris Sedan Join Date: Feb 2011
i put techron in mine about a month ago when it started feeling a lil sluggish... didnt pay any attention but it does feel like i'm not at the gas station as much... def faster and smoother... 1st time i put techron in it it felt quicker but the 2nd time was even better... i think they say it works best after 2 bottles (not at the same time)... the only bad thing about it is that it only lasts for about a month and then slowly starts to change... someone on amazon said Lubro-Moly Jectron fuel injector cleaner lasts a lot longer... i'll probably check that 1 out next
#3 | |
Drives: yaris Join Date: Jan 2011
it seems to be the same, back to normal. but throttle response remains snappier. I must have had some slight buildup on injectors. This must be more noticeable on small engines, as my 5VZFE, which has 190,000 miles on it, I never felt the need to put anything but gas in the tank since 1999. |
![]() Drives: 2010 Yaris Sedan Join Date: Jul 2010
This may sound very stupid, but bare with me, I'm a car novice, but is it safe to use cleaners? My Yaris only has 16,000 on it(2010) and as much as it would be nice to use a cleaner, I'm scared of ruining the car. When I was younger, my parents used a cleaner in their 1980's Pontiac and it killed the engine.
#5 | |
a) no risk it is completely safe to use auto parts store or walmart cleaners that go into the tank only, b) some risk the cleaners that have you in the engine bay sucking into the throttle body could damage the motor if done completely incorrectly (dumped all in at once), either by hydrolock or other extreme pressure situation, or thinning of the motor oil and causing extra wear or failure |
| Does DFCO still work when using cruise control? | rtom | Fuel Economy Forum | 10 | 01-20-2010 12:26 AM |
| Need Truth About Warranty Work . . . | woof | DIY / Maintenance / Service | 17 | 12-12-2009 03:39 PM |
| Got hit at work today, lady drove off. | Prohibit | General Yaris / Vitz Discussion | 41 | 11-04-2009 11:38 PM |
| Drove home from work with a damaged belt and... | AznGouki | DIY / Maintenance / Service | 44 | 09-07-2009 02:08 AM |
| Idea I had, but I can't figure a way to make it work... | kac | Cosmetic Modifications (Exterior/Interior) | 4 | 08-08-2009 09:17 PM |
