![]() Drives: 07 yaris hb - 5 spd Join Date: Aug 2011
Sound Deadening - most effective?
What is the best bang for the buck as far as bringing the in-cabin sound level down. I guess I'd also consider best bang for time involved. I rather not remove the entire interior.
From my own ears it seems like a lot of noise comes from the wheel wells. Is coating the wheel wells (on the outside) the best bet? Also, a lot of people seems to cover the wheel well with metal tape stuff. Is that area a prime culprit? |
#2 | |
advocatus diaboli
In that case, I'd suggest ear plugs.
#4 | |
advocatus diaboli
I used the spray and aluminum tape method and noticed a difference, but I had to tear down the interior. Given the amount of reduction I got from that I can't imagine you having much luck only hitting the underside of the fender liners. There are a few threads around that go into great detail on the subject...
I notice alot of wind noise at freeway speed. You can squeeze in foam caulk rope into your door seal to provide a even tighter seal to prevent wind noise.
Its this stuff: http://www.acehardware.com/product/i...Id=57906222043
![]() ![]() Drives: 2009 toyota yaris 1.3 sedan Join Date: Apr 2010
I sprayed an undercoat rubber spray and it increased insulation by about 40% ..... Not bad ... Still didnt insulate the doors
| 2008 Yaris sedan ‘S’ sound deadening project. | Herbicidal | In Car Entertainment + Electronics (audio / video / alarm) | 155 | 09-04-2011 11:56 PM |
| Yaris SR - JL Audio Install + Sound Deadening (Progress Thread) | Nips | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 03-18-2011 12:42 AM |
| cheap sound deadening | p123456789 | In Car Entertainment + Electronics (audio / video / alarm) | 21 | 11-03-2010 05:06 PM |
| sound deadening material??? are names worth it? | severous01 | In Car Entertainment + Electronics (audio / video / alarm) | 15 | 08-07-2010 09:06 PM |
| Sound deadening questions | cast | DIY / Maintenance / Service | 7 | 03-16-2010 12:46 PM |
