![]() ![]() Drives: 2011 Base Sedan Join Date: Oct 2010
Do stp cleaners work?
Well today there was a sale at a local gas station on fuel additives made by stp
The cleaners were a $1 each so I bought two different ones since that was all that was left on the shelf by the time I got there. I bought 1 Super concentrated fuel injector cleaner(black bottle) 1 complete fuel system cleaner I plan on using the complete cleaner on my yaris and the fuel injector for my dads truck the bottle says it treats 21galons and I know the yaris has 11 so I plan on using half the bottle (correct me if I shouldn't) do these things really work or should I give them away? (I plan to use it on my yaris b/c I don't know how well the car was maintained before I bought it) and if it helps my tank is only missing one bar, almost full
http://db.tt/QIWZ2E2 Click to signup for dropbox, and get bonous space, I do too! |
![]() Drives: 2009 Toyota Yaris Join Date: Feb 2011
I prefer the Lucas Fuel injector cleaner. It works really well.
SHELL V-Power and the TECHRON work well . STP , haven't used that in years . There's also BG products . Can find that at TOYOTA parts departments , http://www.bgprod.com/products/products.html .
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
I use Lucas for the diesel. Have not tried on the Yaris yet.
Making a decision without following it with an action is still a fantasy. |
Mr. 155 and climbing
I used to use STP products for my 86 escort when I had it in the early 90s. did the job back then, have no idea now.
![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2011
Most gasolines sold today have injector cleaners as part of the additive package. This makes off-the-shelf additives somewhat redundant.
"LibertyRides!"
Drives: 2010 Yaris 3Dr LB | 2020 Stang Join Date: Mar 2010
I don't use fuel system cleansers, octane enhancers, fuel conditioners, and gas treatment products. I do use gasoline fuel stabilizers for ethanol gas.
http://www.fuel-testers.com/review_g..._products.html http://www.jackssmallengines.com/gas_stabilize.cfm Cheers!
~ Mark ~ 2010 Yaris 3-Dr Liftback, 5-Speed Manual, P185/60R 15, Bayou Blue Pearl I Love my YARIS Most miles Tank: 538 tank/10.148 gal = 53.015 MPG / Most MPG: 54.95 MPG (ethanol) 425 tank/7.73 gal "The evils of government are directly proportional to the tolerance of the people." -- Frank Kent |
![]() ![]() Drives: Toyota Belta Join Date: Feb 2010
Do fuel injector cleaners fix a rough idle and a bad fuel average?
Drives: yaris Join Date: Jan 2011
I just did a bottle of techron on my 19,000 2010 yaris HB automatic
what happened was: -for that 1 tank, gas mileage dropped -almost immediately, throttle response improved -throttle response continued to stay 'peppier' It surely had to do something to clean my injectors. My yaris never ran bad...I just figured throw in some bg44k or techron and techron was what I found first. it does work. next 20,000 miles I'll do another bottle |
#10 | |
![]() ![]() Drives: 2011 yaris rs Join Date: Nov 2010
Just curious, did your gas mileage improve after that 1st tank went down?
0-60 IN UNDER FIVE
Drives: 2008 Blk on Blk Yaris Sedan Join Date: Feb 2011
i put techron in mine about a month ago when it started feeling a lil sluggish... didnt pay any attention but it does feel like i'm not at the gas station as much... def faster and smoother... 1st time i put techron in it it felt quicker but the 2nd time was even better... i think they say it works best after 2 bottles (not at the same time)... the only bad thing about it is that it only lasts for about a month and then slowly starts to change... someone on amazon said Lubro-Moly Jectron fuel injector cleaner lasts a lot longer... i'll probably check that 1 out next
#12 | |
it seems to be the same, back to normal. but throttle response remains snappier. I must have had some slight buildup on injectors. This must be more noticeable on small engines, as my 5VZFE, which has 190,000 miles on it, I never felt the need to put anything but gas in the tank since 1999. |
![]() Drives: 2010 Yaris Sedan Join Date: Jul 2010
This may sound very stupid, but bare with me, I'm a car novice, but is it safe to use cleaners? My Yaris only has 16,000 on it(2010) and as much as it would be nice to use a cleaner, I'm scared of ruining the car. When I was younger, my parents used a cleaner in their 1980's Pontiac and it killed the engine.
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
+1. Tried it once and it actually improved my rating by only 3 miles per tank, though it may have been somewhat unnecessary because I'm only at 75K on the original fuel pump and filter. Suppose someone with higher mileage could give you a better opinion maybe?
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
#15 | |
a) no risk it is completely safe to use auto parts store or walmart cleaners that go into the tank only, b) some risk the cleaners that have you in the engine bay sucking into the throttle body could damage the motor if done completely incorrectly (dumped all in at once), either by hydrolock or other extreme pressure situation, or thinning of the motor oil and causing extra wear or failure |
| Does DFCO still work when using cruise control? | rtom | Fuel Economy Forum | 10 | 01-20-2010 01:26 AM |
| Need Truth About Warranty Work . . . | woof | DIY / Maintenance / Service | 17 | 12-12-2009 04:39 PM |
| Got hit at work today, lady drove off. | Prohibit | General Yaris / Vitz Discussion | 41 | 11-05-2009 12:38 AM |
| Drove home from work with a damaged belt and... | AznGouki | DIY / Maintenance / Service | 44 | 09-07-2009 03:08 AM |
| Idea I had, but I can't figure a way to make it work... | kac | Cosmetic Modifications (Exterior/Interior) | 4 | 08-08-2009 10:17 PM |
