#1 | |
I used the HID Install thread to disassemble the light. Yaris LB HID Installation Two differences, I didn't completely remove the front bumper, I left the bottom bots/fasteners in place and lightly pulled it out of the way to remove the light. I didn't bake/heat the light housings, I was able to work the lights apart and cut the sealant as I went. FYI if you end up doing this: The chrome finish on the housings is really easy to scratch. Wiping it with anything other than a really soft cloth will dull the finish and leave scratches. The masking tape didn't leave any blemishes but I was careful to place it and not move it when it was partially stuck down. Finger prints are a pain to get off of the housing, don't touch any part that you aren't planning on painting and wear clean latex gloves while disassembling, masking and reassembling the light. |
![]() ![]() ![]() Drives: 2010 5 Door Join Date: Feb 2011
how did you seal it back up?
lol okay |
High Temp Silicone. I used it sparingly around the joint between the lens and the lower housing after I reassembled them. I wanted to be able to separate the parts easily if I decide later to add some LED's or do something else to dress them up little. If I end up with a little condensation in them, I'll pull them and reseal them.
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 08:42 PM |
| Sedan HID Projector Retrofit Headlights | !yaris! | Cosmetic Modifications (Exterior/Interior) | 10 | 10-26-2017 02:31 AM |
| Painted the headlights today | nick.dollimount | Cosmetic Modifications (Exterior/Interior) | 13 | 06-09-2010 05:51 AM |
| Finally painted my headlights, too | coffiend | Cosmetic Modifications (Exterior/Interior) | 8 | 06-07-2010 04:44 PM |
| [SOLD] Painted 07 LB Headlights | enobmort42 | Items for Sale by private party | 19 | 12-18-2009 06:11 PM |
