Old 09-17-2011, 09:33 PM   #1
Murtaza_murti
Drives: Toyota Belta
@CTScott, any other solution?
Murtaza_murti is offline   Reply With Quote
Old 09-17-2011, 09:51 PM   #2
If moving the needle with the car running didn't work, then you may have damaged the little servo motor that drives the needle.
Old 09-17-2011, 10:04 PM   #3
Murtaza_murti
Oh, well the needle works though. It's dropped all the way down. Sorry for going off-topic but I needed to ask, if I go for the odometer that comes with the tachometer will it be just plug and play or, will I have to do something to it in order to make it work?
Old 09-17-2011, 10:15 PM   #4
It's plug and play as long as you match your ABS or no ABS configuration.
Problem Starting Car drunkwithwords General Yaris / Vitz Discussion 3 07-21-2010 04:01 PM
Yaris Central Locking Problem pbasuita UK 0 07-10-2010 03:46 AM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 08:11 PM
How can I get in touch with Toyota Regional Offices in Houston? woof DIY / Maintenance / Service 11 11-28-2009 09:29 PM
Speedometer Trouble jonathancash DIY / Maintenance / Service 7 05-12-2009 03:04 AM
