Old 09-17-2011, 10:04 PM   #1
Murtaza_murti
Drives: Toyota Belta
If moving the needle with the car running didn't work, then you may have damaged the little servo motor that drives the needle.
Oh, well the needle works though. It's dropped all the way down. Sorry for going off-topic but I needed to ask, if I go for the odometer that comes with the tachometer will it be just plug and play or, will I have to do something to it in order to make it work?
Murtaza_murti is offline   Reply With Quote
Old 09-17-2011, 10:15 PM   #2
It's plug and play as long as you match your ABS or no ABS configuration.
Problem Starting Car drunkwithwords General Yaris / Vitz Discussion 3 07-21-2010 04:01 PM
Yaris Central Locking Problem pbasuita UK 0 07-10-2010 03:46 AM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 08:11 PM
How can I get in touch with Toyota Regional Offices in Houston? woof DIY / Maintenance / Service 11 11-28-2009 09:29 PM
Speedometer Trouble jonathancash DIY / Maintenance / Service 7 05-12-2009 03:04 AM
