#1 | |
- Contact - Contact || Coil
#2 | |
![]() Drives: 2011 3Dr Hatch Join Date: Apr 2011
When I do this what should the multimeter say or what setting should I put it on. I have never done this before and I have someone letting me use their multimeter. Thanks |
#3 | |
If the one you borrowed doesn't have "continuity" then put it in Resistance mode (Ohms). If it has multiple ranges for resistance, it doesn't matter which you use. In resistance mode it will say something like "OL" on the screen with the probes not touching anything and if you touch them together it should go down to zero (or mighty close there to). Same as above, when you touch the 9volt battery to the coil terminals the reading should change to just like you touched the probes together (that is it should be near zero).
| changing reversing bulbs and now other things don't work | willygoodness | DIY / Maintenance / Service | 10 | 03-28-2012 09:46 PM |
| Gas Savings Tips That Don't Actually Work! | MadMax | Fuel Economy Forum | 21 | 03-09-2011 09:25 AM |
| November: Big Yaris Short Shifter Sale! | TWM Performance | Sponsors Classifieds Area | 14 | 12-12-2006 10:50 AM |
| TWM Yaris Short Shifter Sale! | TWM Performance | Sponsors Classifieds Area | 9 | 08-28-2006 03:37 PM |
| TWM Short Shifter/Shift Knob Sale! | TWM Performance | Performance Modifications | 0 | 07-17-2006 05:08 PM |
